Old 10-21-2002, 10:09 PM   #1
big71
big71's Avatar
help please about brakes
a frend of my has a 1970 drum front and drum rear he does not want to change over to disk but he want to put a power booster on it what port valve does he need or all them the same i thought disk and drum port valve was diffen. if you can help thanks
big71 is offline   Reply With Quote
Old 10-21-2002, 11:21 PM   #2
racedvl
racedvl's Avatar
Disk and drum brakes use diffrent P-valves.
racedvl is offline   Reply With Quote
Old 10-22-2002, 05:15 AM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
If you are going to use your old single outlet master, no valve is meeded. Dual master cylinders can be plumbed for cross or front/rear braking. Either way, no valve for all drums.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 10-22-2002, 08:44 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
If you get the master cylinder for a drum/drum setup you don't need a proportioning valve or cross-plumbing. My 69 has drum/drum power brakes with a dual master cylinder.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-22-2002, 08:57 AM   #5
jmil1974
Ain't we cute?
jmil1974's Avatar
Tell him to think about www.praisedyno.com for some shoes. That, with power, should make his braking very nice (on par with factory disc).
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 10-23-2002, 12:18 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Never seen a single resivour master cylinder on these trucks...power/non power, drum or disc....they all had daul resivours as far as i know.
Old 10-23-2002, 01:09 AM   #7
68 Stepside
huh?
68 Stepside's Avatar
I agree with longhornmail. My 66 3/4 ton had a single res; and my 67 C10 panel has a dual...
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-23-2002, 05:00 AM   #8
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
You're right about the single resevoirs only to '66. I was thinking about my panel when I wrote that, which I changed to dual with drums, then put 78 x-member in, with prop valve.
Nevada City, CA
Everett, Washington
