Old 10-03-2006, 03:25 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Back of cab trim molding........Proper way to re-install?
I have to put the chrome trim on the back of the cab on my K-20..........Could someone shed some light on the proper way to re-install it? The way I took it off will make a mess of the new paint, and I would like to know the right way to do it.
TIA
TP
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 10-04-2006, 10:55 AM   #2
Shock_Me
Shock_Me's Avatar
Re: Back of cab trim molding........Proper way to re-install?
I'd like to know this procedure as well. I have to install some kind of stud kit to my cab though, because it came without that trim piece originally.
Pete
Shock_Me is offline   Reply With Quote
Old 10-04-2006, 02:03 PM   #3
wibilly
wibilly's Avatar
i bought screws and clips on ebay for mine from a company called florida fastener but have not instaled the trim yet
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-04-2006, 08:15 PM   #4
TP from Cntl PA
I haven't installed it yet...........But I wish someone would be able to help because I don't want to scratch up the nice new paint.
Old 10-04-2006, 08:34 PM   #5
Mudder
Mudder's Avatar
My body man has a believe it is called a stud gun. It attaches the little studs to the metal for the clips. Not sure that you can get screws small enough to work.
Mudder is offline   Reply With Quote
Old 10-04-2006, 08:41 PM   #6
Aarons72s
Do you guys still have the studs on the back of your cabs? If yes then the procedure is to mount the clips on the studs. Then snap the trim on top of it. 73-79 ford pickups have a similar trim on the back of there cabs and that is how to install it.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-04-2006, 09:40 PM   #7
TP from Cntl PA
Aaron
Yup, I have them on mine.........The out clip on each side(One closest to the door) was broke, so I slid it off the rest of the clips. I was sure it didn't go back on the same way, but wasn't sure if the molding just snapped back on them either.
Thanks for your help.
Old 10-04-2006, 10:42 PM   #8
Aarons72s
No problem guys.
Aaron
Old 10-04-2006, 10:44 PM   #9
Mudder
Mudder's Avatar
Once you slide the plastic clips on the little studs the chrome should just snap on to the clips.
Old 10-06-2006, 11:22 AM   #10
AH619
AH619's Avatar
For Those Of You That Dont Have Studs Already Check Out Ebay #220033068758. I Bought This Kit And It Worked Out Great. It Did Help That I Had A Cab Close That I Used As A Pattern So There In The Right Place. You Can Buy The Plastic Pieces Seperatly If You Have The Chrome Already.
AH619 is offline   Reply With Quote
