Old 10-04-2006, 12:16 PM   #1
Luvlegs
Luvlegs's Avatar
Mixing in the rear end
My mistake - while at parts counter, asked what rear gear lube to put in differential - he gave me one bottle - I asked if that was enough for a complete fill - he ran and grabbed another off the shelf. AFTER I put all of one and almost all the second in, I noticed he had given me one bottle of Mobile 80W-90 and one of 80W-140 - I never thought to check the two. All of the 140 went in and darned near all the 90.
Do I empty and start over or go with it for a while and then change out?
On the positive side, I also found that after a few taps with a hammer to loosen, the plug came out nicely using the end of a short 3/8" extension (I didn't have any square drives).
It's starting to look pretty so heres a quick pic too.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-04-2006, 01:16 PM   #2
Green Machine
Green Machine's Avatar
Re: Mixing in the rear end
I don't think that is going to hurt anything, just a little thicker than you wanted - like a 80w-110. It might be a little stiff if you drive in cold weather. here in Iowa I like to run synthetic in the rear diffs, gets pretty cold here-guess I would run it for a while and change to synthetic, no big hurry. If the previous oil had been in there a long time this will clean it up before the next change. If you complain, the might give you some free lube for the next change ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-04-2006, 01:19 PM   #3
Luvlegs
Luvlegs's Avatar
just needed to hear the same thing I was thinking from someone else - at least no fire alarms were pulled! Thanks.
1972 C10 L6 3OTT
Old 10-04-2006, 01:35 PM   #4
timcos
Chief Honcho In Charge
timcos's Avatar
Just to jump in and not hijack the thread...
Just to make myself feel better...I have a 4wd...can I just remove the covers, replace the gasket and fill it with new synthetic? I ask because the fluid has not been touched for two years (as the truck sat still) and who knows how long before then it was changed? I am noticing no adverse condition right now.
Is it that straightforward...or am I missing something?
Thanks,
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 10-04-2006, 01:50 PM   #5
Luvlegs
Luvlegs's Avatar
There's really nothing else to it that I know of - I took off the old cover, caught the old fluid, let it drain all out - cleaned mating surface for the new gasket, I put on a little gasket sealer, bolted on the new cover, added fluid until it was at level of fill hole. Simple actually.
1972 C10 L6 3OTT
Old 10-04-2006, 02:05 PM   #6
wolfthing2000
BE CAREFUL. If the truck sat for years, the inner axle seals may have dried out ( on some models) and the new synthetic could leak out. I would be darned sure there aren't any leaks for sure.
wolfthing2000 is offline   Reply With Quote
