Old 10-04-2006, 03:53 PM   #1
shane72_383
shane72_383's Avatar
Lowering Help
So i think i've decided to go ahead and cut the aprings on my 72. Im looking for some advice on doing this, should i do it? Advantages/Disadvantages, and any general tricks that anyone might know. Thanks
shane72_383 is offline   Reply With Quote
Old 10-04-2006, 04:11 PM   #2
jimmydean
jimmydean's Avatar
Re: Lowering Help
You can only cut the front ones. If your springs are original, I would highly recomend spending the money and getting new springs in the height you want. New springs and new shocks will improve your ride a lot!
jimmydean is offline   Reply With Quote
Old 10-04-2006, 04:48 PM   #3
wannabeburbowner
wannabeburbowner's Avatar
Re: Lowering Help
I cut my stock front coils. I used a 4 1/2" angle grinder. If I remember right I just took off a half coil and it lowered it about 2" maybe just a hair more. They have been on there for about 6 months and are doing just fine.
71 Chevy Long Bed (gettin' bagged)
84 GMC K1500 (Sold)
85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it )
85 Monte Carlo SS clone T-top (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
wannabeburbowner is offline   Reply With Quote
Old 10-04-2006, 04:54 PM   #4
slammed71
slammed71's Avatar
Re: Lowering Help
Start a half, you can alway's cut more but you can't put it back!
slammed71 is offline   Reply With Quote
Old 10-04-2006, 08:25 PM   #5
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Lowering Help
Cutting 1 coil will net you about 2-1/2". Like said, use an angle grinder or you can use another method. I would stay away from the torch if you can.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-04-2006, 08:44 PM   #6
low sierra
Old Time Rodder
low sierra's Avatar
Re: Lowering Help
cut one coil off the front springs on my 79 in july of 81 and it is still working very well. used a flip kit on the rear and was not satisfied with the results because the rear was lower than the front. to get the front end down more I cut another 1/4 coil off and it was way to much causing lower ball joint problems, don't go past one coil. put in new springs cutting 1 coil again and took the truck and a new set of MOOG lower ball joints to the alignment shop. when I got it back the new ball joints had lowered it about another inch. it was perfect ratio front to rear, just a slight forward rake.
by the way when I ordered the flip kit, first I had ever seen advertised, the instructions told me to cut front springs and remove all the bump stops front and rear.
sorry for the long story, hope this helps.
I forgot to say that I heated and flattened the bottom of the spring as well.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980)
Replacement cab had A/C which now works, made a real truck out of it
84 MC 305 350TH 3.08
4 wheel disc finally
My daily driver again
low sierra is offline   Reply With Quote
Old 10-04-2006, 10:10 PM   #7
Shane
Shane's Avatar
Re: Lowering Help
save your money and buy dropped springs, shouldn't cost more than $250 for both front and rear .... your kidneys will thank you for it later on.
Shane is offline   Reply With Quote
Old 10-04-2006, 11:51 PM   #8
shane72_383
Re: Lowering Help
I think i like your idea Shane (we have the same name by the way) $250 isn't bad and i want to go 3 or 4 in the front, any other problems that i might run into doing it the "right way?"
Old 10-05-2006, 01:49 AM   #9
jimmydean
jimmydean's Avatar
Re: Lowering Help
To go more than 2.5" in the front, you will need drop spindles. To do it "right", get a 3/5 front/rear kit. For $700, you can get spindles, front/rear coils, shocks, shock relocators, track bar, and u-bolts.
I would add a c-notch kit to that, but that's "right".
I couldn't decide how low was low enough without being too low, so I bit the bullet and went bags. I have about $1400 into my setup, but I had to add discs on my '69. It adds up FAST, but you will be better off in the long run if you do it right the first time.
