Old 10-05-2006, 08:51 PM   #1
ssjones
ssjones's Avatar
kickdown wiring
Quick question. I have a 1972 3/4 ton and have done a painless wiring kit. I have a turbo 400 tranny and need to know how the kickdown is wired on the gas pedal. I have one wire running to the tranny from the gas pedal switch and there is another connection on the gas pedal switch that I dont know where it goes. Could this be a ground connection?
I just pulled my 350 and replaced it with a 406 and rebuilt the 400 tranny. I will post pics very soon. Thanks for all the help this site has provided during this motor swap.
Thanks,
1972 Chevy Cheyenne 20
1979 Chevy Camaro
2007 Chevy Avalanche
2005 Mini Cooper
ssjones is offline   Reply With Quote
Old 10-05-2006, 08:59 PM   #2
gator2511
gator2511's Avatar
Re: kickdown wiring
The other wire on the switch should be the 12 volt or hot wire. When the switch is closed the power runs through the switch down to the tranny connection. The solenoid goes to ground through the case.
gator2511 is offline   Reply With Quote
Old 10-05-2006, 09:04 PM   #3
ssjones
ssjones's Avatar
Re: kickdown wiring
Ah... Thanks. Stupid question but does it matter which connection goes where?
1979 Chevy Camaro
2005 Mini Cooper
Old 10-05-2006, 09:07 PM   #4
gator2511
gator2511's Avatar
Re: kickdown wiring
No stupid questions man. You should see some of the ones I ask. Shouldn't make any diff which terminal you put it on since it only serves to close the circuit from the power to the tranny.
