Old 10-13-2006, 02:32 PM   #1
Eric M.
Problem with Death Wobbles in a 2wd
I've got a friend who's experiencing Death Wobbles (steering shimmy). He's got a 2wd, 75 GMC dually that experiences death wobbles at about 80 MPH. Yes, I told him a 75 GM dually was never built to go 80, but, he's owned it for years and it never Wobbled before.
All the front end is new, new steering box, alum. Weld rims, he's tried several sets of tires. Shocks good, brakes checked.
Any ideas?
Thanks,
Eric M.
Eric M. is offline   Reply With Quote
Old 10-13-2006, 02:46 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Problem with Death Wobbles in a 2wd
I presume that he has had his new wheels balanced and when you mention that his front-end is new that he has replaced the ball joints, bushings, center link, tie rod ends, pitman and idler arm. Did he have a front-end alignment afterwards? My guess is that the problem is in the front end suspension (alignment or setup).
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 10-13-2006, 02:46 PM   #3
jimmmie '79 Cheyenne
Pulling this from way back when I worked at a frame and wheel shop - If the caster is either too little or too much (can't remember which) , it can cause a shimmy at high speed or when you hit a bump at a lower speed.
jimmmie '79 Cheyenne is offline   Reply With Quote
Old 10-13-2006, 02:49 PM   #4
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I had a wobble at exactly 45 mph in my Suburban, I chased it for a while, then gave up. I always assumed it was coming from the front end. It finally disappeared when I replaced my wasted rear spring bushings while I was doing my flip kit.
Maybe the rear end is out of whack a little or possible driveline vibes? At 80 mph, who knows...
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 10-13-2006, 03:05 PM   #5
Eric M.
Yes, he's done all the above mentioned. He did realign the front after his work and has played a bit with the castor (he's still playinh around with castor settings). He had the truck on a dyno up to 120 MPH and no vibration from the rear.
Thanks,
Eric M.
Old 10-13-2006, 03:22 PM   #6
84 400
Sb 400 club
84 400's Avatar
Hmm this is very interesting. If it was not doing it before it would lead me to belive that somthing was done wrong during the front end rebuild. Not that i am doughting his work but that could be a possible reason or a defective part. Also how is the steering colum its self? any play in that? Is it lifter? ALso do you have any pics of the truck? i know it is off topic but a dooly pulling those kind of speeds must be a pretty cool truck
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-13-2006, 03:43 PM   #7
Eric M.
I'll have him check out the steering column. Not lifted, he uses it for towing his boat.
Here's a link I posted from a while back, it's more about the boat, but there is some info about the truck.
Half way down the page, after the Blazer and the goofy animal pics. (I swear, that's not me
http://blog.mannon.com/archives/000004.html
Thanks,
Eric M.
Old 10-13-2006, 03:57 PM   #8
84 400
Sb 400 club
84 400's Avatar
wow those are both sweet the black and white one. If i had the money i would buy a 80 dualy suberban and drop a motor like that in it with a 6 speed trans and lower it just a bit. That black truck is sweet
1985 C10 LWB Sold
Old 10-14-2006, 11:57 AM   #9
magnethead
7000 #'s of american IRON
magnethead's Avatar
we've gotten my dually to 90 MPH. Unfortunately, that also made fuel comsumption be around 90 gallons per hour (lol)
magnethead is offline   Reply With Quote
Old 10-16-2006, 12:02 AM   #10
lurch115
lurch115's Avatar
have him check all the rear suspension parts too....an easy way to find out if something is worn out such as leaf spring end bushings or if the leaf springs them selves are bad is to drive down a smooth road and rock the steering wheel back and forth...if the back end seems rather loose, or dips to one side then something is worn out...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 10-16-2006, 12:31 AM   #11
crazy longhorn
Fabricate till you "puke"
He!!, that old dually should run 100 mph + with no "wiggles". If it were mine, I would have the balance on the fronts checked again.....& if that dont get it, I would look at drive shaft issues, or driveline angle problems. Best of luck... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-16-2006, 02:41 AM   #12
84 400
Sb 400 club
84 400's Avatar
Rear leafs could be it to my freinds does that same thing because his are shot. with towing and all maybe your freinds are worn ?
1985 C10 LWB Sold
Old 10-16-2006, 08:13 AM   #13
magnethead
magnethead's Avatar
x3
my rear springs are all but flattened out...
Old 10-17-2006, 10:21 AM   #14
Eric M.
It isn't coming from the rear. See the above post. He put the truck on a rear wheel dyno and ran it up to 120 MPH checking for vibrations. Nothing. It isn't coming from the driveshaft, balancer, rear tires, rear leafs or any part of the rear suspension. It would've showed up when on the dyno.
Thanks,
Eric M.
Old 10-17-2006, 01:01 PM   #15
mhicks
mhicks's Avatar
Tire separating? I have had that happen before and could not see it.
mhicks is offline   Reply With Quote
Old 10-17-2006, 05:01 PM   #16
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The truck is tied down tight on a dyno, the springs are loaded. An unloaded rear end will allow the loose bushings/springs to get loose and vibrate. Try jacking the trucks rear up on jack stands and the run it up to 80-90 mph but be very careful.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 10-18-2006, 02:13 AM   #17
84 400
Sb 400 club
84 400's Avatar
i agree with the above post but it is very very dangerous!
1985 C10 LWB Sold
Old 10-18-2006, 05:45 PM   #18
Eric M.
He's on his second set of new tires in 2 months (trying different brands) and no difference.
Thanks,
Eric M.
