Old 10-19-2006, 09:36 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Question late model power steering pump removal
hi guys,
i have '72 chevy p/u with a 92 suburban serp. belt setup on it. i have a flex-a-lite twin fan setup as well. my question is basically this: how do i remove the pump?? i am hoping that there is someone else on this forum that has switched to a late model serp. setup that has had to do this already & can give me some very appreciated insight!! i am really at MY WITTS END!!. i don't think that there is enough room to remove the pulley 1st. maybe someone can give "step by step" instructions for the order to do things anyways. i am able to get to all the bolts except for the one behind the pulley on the pass. side.
if anyone here could (would) help me i would be very greatful!!!
thanks for the time to help!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 10-19-2006, 10:02 PM   #2
qksilver
Re: late model power steering pump removal
I think the only way to access the bolts is to remove the pulley
qksilver is offline   Reply With Quote
Old 10-19-2006, 10:23 PM   #3
rodstored-72
chevy truck fan
does anybody know if a puller from a local parts house work on the space?? i have about 3.5" of free room???
thanks for the help.
Old 10-19-2006, 10:33 PM   #4
qksilver
That should be enough if you use the collar style puller. It will be close though
Old 10-19-2006, 11:11 PM   #5
kwmech
MY 90 Burb is the same way, have to remove the pulley first, I have to jack the fan shroud a little bit to get the puller lined up straight
Old 10-20-2006, 10:55 AM   #6
rodstored-72
chevy truck fan
does anyone know if the "collar style" puller is available to rent from the local parts store?? i assume that maybe the counter person would know what that style of puller is.
thanks!!
rodstored-72
