Old 10-20-2006, 08:39 PM   #1
77pdxC-10
Quick radiator question?
I have a friend who is going to sell me a brand new radiator for 100 bucks! It's for a 454 but it is the aluminum with plastic tanks. Question is what lower and upper mounts do I use? Pretty sure it is not as wide as a 4 row but not as small as a 2row! Anyways if there is someone using this radiator (which if I remember there is) or have any knowledge please chime in. Need to replace my radiator this weekend!
77pdxC-10 is offline   Reply With Quote
Old 10-22-2006, 12:20 PM   #2
77pdxC-10
Re: Quick radiator question?
Do I have everybody stumped with this one . Hoping to get this done this weekend!
Old 10-22-2006, 06:40 PM   #3
Prerunner1982
Prerunner1982's Avatar
The 454 radiator should be a 4 core, you will need a new 1 piece upper bracket which you can get from a dealership as well as new rubber isolators... other than that it is a direct bolt in. Sorry this may be a bit late, most of us were probably wrenching this weekend..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-22-2006, 06:43 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You will need the top bracket to bolt the new radiator. The bracket is a single piece. The smaller radiators used two small brackets. You will also need the two upper and lower rubber bushings. The bushings cost 4.95 each at www.lmctruck.com. The bracket is also 19.95.
I've been running a 454 aluminum core with the plastic ends for 4 years now. No problems what so ever. It has two 14" electric fans bolted to it too. I also run a zinc anode in it too. The zinc anode reduces corrosion inside the engine and radiator. The zinc anode just hangs off a ring at the radiator neck under the cap. You can purchase the zinc anode at a parts store or www.jcwhitney.com.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-22-2006, 06:50 PM   #5
Prerunner1982
Here is a pic of the top mount.
Old 10-22-2006, 08:11 PM   #6
77pdxC-10
So just to make sure aluminum or copper if its for a 454 then you use 454 brackets! Here is the auction below my friend has going for it. Obviously he lives in Michigan but he swears its only a 2 row but he ordered it for a 454!
http://cgi.ebay.com/ebaymotors/73-87...QQcmdZViewItem
Old 10-23-2006, 09:30 AM   #7
Prerunner1982
Its hard to tell from the one pic he has...
Jon
Oklahoma Roll Call
Old 10-23-2006, 12:01 PM   #8
bigarmzz
bigarmzz's Avatar
for the 4-core rad conversion-
all my stuff, i bought from www.chevyduty.com, so these are there part #'s:
78-772 radiator rubber isolators (ya need 4) $3.95 apiece
78-845 top radiator cover $14.95
78-955 4-core 1 piece fan shroud $19.95
433730-4 core radiator auto zone part #, $158.99
(this is the part # for a 1984 454 1 ton)
the top rad cover mounts to the rad support, and the shroud holding it in place, everything else, bolts, clips ya just re-use from your stock set up
pretty cheap for this conversion by the way, all the parts i bought from chevy duty were GM
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
