Old 10-25-2006, 10:27 PM   #1
beater69
Sinister Exaggerator
beater69's Avatar
Shift Improver? TransPak? What's the dif?
B&M makes both but it is hard to tell excactly what the difference is from the summit catalog and the b&m website isn't much better. TransPak appears to give the ability to hold gears longer. and it looks like it comes with the filter. Is the shift firmness otherwise the same? What is everyone out there running? How hard is the street/strip setting? I want a good hard shift at 1/2 to full throttle but when i'm just cruising around I don't want it to rattle my teeth for a 1/4 throttle shift.
Thanks guys
69 c10 Chevy Long Fleet 350/350 *under construction*
Poor man's disc brake upgrade with HydroBoost from '82 diesel
Blazer tank with "John Fabris" stake pocket filler (Genius!)
beater69 is offline   Reply With Quote
Old 10-25-2006, 10:32 PM   #2
wibilly
wibilly's Avatar
Re: Shift Improver? TransPak? What's the dif?
i used the trans go kit from summit in my vette and love it. when i called summit to order the b&m stuff they talked me out of it and into trans go
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-25-2006, 10:35 PM   #3
crazy longhorn
Fabricate till you "puke"
the transpac is a little "brutal" on the low rpm shifts, for a street driven truck I would go with the improver......or better yet look at the Tran-Go kits. I have run both B+M, & the Trans-Go, but prefer thr Trans-Go. The give the shift you want in traffic.....but hit hard when cranked up L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-25-2006, 10:52 PM   #4
beater69
beater69's Avatar
The transgo is $80 and the b&m shift improver is $30. Is the transgo that much better? You can set the b&m shift improver to "rv/towing" or "street/strip"....how bad is "street/strip"?
Thanks guys
Old 10-25-2006, 10:59 PM   #5
kaycee
kaycee's Avatar
I had the B&M in my 70 wasn't to bad nail it to the floor and it would bark the tires when it shifted.It was not bad at all when you were cruising,I would build another one the same way if I were to do it again.Allso had no problems with it for 15 k miles then I sold the truck.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 10-26-2006, 12:10 AM   #6
beater69
beater69's Avatar
do you remember if you had it set for rv/tow or street/strip?
Old 10-26-2006, 02:14 PM   #7
kaycee
kaycee's Avatar
Street/Strip I did the whole master kit at this time allso, new clutches,bands etc.
2005 FXDWG stage3
63 IMPALA 327
