#51 |
Re: PO has me PO'd
Dude seriously, they are going to scream foul on this mod., I may have even out thought myself-ROTFLMAO
#52 |
Re: PO has me PO'd
#53 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: PO has me PO'd
Stop holding back whats the secret mod??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#54 |
Back in the sticks
Re: PO has me PO'd
Nice looking work and nice pics! Keep them coming! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#55 |
Re: PO has me PO'd
Not sure if I can bring myself to do it again, although it should match the drivers side. It"s really hideous,but I think I'm forced to do it again. I'm on the fence!
Thanks Jeff
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-27-2006 at 05:56 AM. |
#56 |
Designated A-hole!
Re: PO has me PO'd
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 10-27-2006 at 06:18 AM. |
#57 |
Re: PO has me PO'd
where did you get the repair panel for the kickpanel area?
#58 |
Re: PO has me PO'd
My replacement panels are all Goodmark, find a vender on the west coast and it will save shipping. I think GMC Pauls is in your area.
In one of the pics., you can see that the panel is a 1/4" short, so you will probably have to section it. I didn't do mine yet, but if you hang around I'll take pics. when I get to that area. I'm getting ready to start the cab mount to support channel today. Jim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-01-2006 at 07:23 PM. |
#59 |
Re: PO has me PO'd
#60 |
PROJECT 7DEUCE
Re: PO has me PO'd
He must have painted the other side pink!!!!!!
#61 |
Can't wait to retire!!
Re: PO has me PO'd
Yeah...what he said! Looking forward to the next set of pics.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#62 |
Re: PO has me PO'd
Not pink, but I may get my user name turned to yellow!!!
Back to work...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-28-2006 at 11:42 AM. |
#63 |
Re: PO has me PO'd
The ol' man has finally went off the deep end!!! Cutting holes in his new floorboards, what on God's green earth was he thinking. Maybe he built to many car models with the windows closed, who knows.....
Any way, putting in the cab support box is a real challenge, not impossible, but probably the most difficult of the project. Tied to the z brace first with zip screws, makes it easier to manage. I like to drill a 1/8" hole first so the threads don't catch on the outside layer of sheetmetal and walk up, thus separating your joint. After that is attached, you can pull back on the cab support to line it up with the leading edge of the floor board. Don't forget you have a doubler plate that mounts the front fender in. the doubler has to sit against the forward edge of the cab support, not the flange, but the leading edge of the cab support. Don't be afraid to use a body hammer to tighten up the flanges and corners after it is zip screwed, they bend very nicely with a little bit of effort... OK here's the pics. ![]() ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-29-2006 at 01:24 PM. |
#64 |
Re: PO has me PO'd
Here's some more...
BTW, check the welds on your cowl to floorboard brace, both of mine were lose. About 7 or 8 spot welds broke loose, so this is a good time to reweld them. ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-31-2006 at 07:49 PM. |
#65 |
Re: PO has me PO'd
Looks SOOO good with that new metal!
![]() What are the 'goals' for this coming weekend? |
#66 | |
Re: PO has me PO'd
How did you make out with cutting that full top, did it look right when you were dun?
#67 | |
Re: PO has me PO'd
![]() When I did my top, I cut it "fat", so I could do some final trimming but never did get to the trimming part. It looked okay and I'm still considering it. |
#68 |
Re: PO has me PO'd
'Cause I already have the xtra NP205, I found demensions of the adapter plate.
Post up pics. of what you have so far on the top, I'm considering it, but I thought I would let you do all the thinkin'. J
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-03-2006 at 01:05 PM. |
#69 |
Re: PO has me PO'd
Any progress lately?... We're waiting for more pics.
Thanks.
#70 |
Re: PO has me PO'd
Just a little work on the 'A' post patch panel, totally screwed it up, so I'll have to call this thread what not to do. Soon as I download my camera, I'll put it up.
'Honey Do' list had to be worked on last weekend!!!! J. Here's some pics: ![]() ![]() ![]() ![]() ![]() Not much work done, and I have to work this week end, so it will sit awhile. Did get my new trans. and transfer case though, and my 3/4 ton master cylinder and booster came in. Thanks to Frank's Pick-M-Ups
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-08-2006 at 06:55 PM. |
#71 |
Re: PO has me PO'd
OK, here is my current progress over the weekend:
![]() ![]() ![]() ![]() ![]() Still have to clean up reinforcement plate for front fender and install, then the the "A" post patch panel is done. Unbelievably strong at this point, you can shake the truck by the repair work!! J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-13-2006 at 08:32 PM. |
#72 |
The LuvShack Garage
Re: PO has me PO'd
Looking good
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#73 |
Re: PO has me PO'd
The 'end' is in sight. Thanks for the comps.
You must have your hands full with 2 of these things! J.
#74 |
Re: PO has me PO'd
Excellent work!
Looking forward to the next set of pics. ![]()
#75 |
Re: PO has me PO'd
First off, great pics, great job, love to see the progress. Will help me when I get into mine here soon.
Second, I'm dying to know what those things are sticking up from your new metal. I'm assuming your using them to hold everything together aligned until you weld. Inquiring minds want to know?
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
