Old 10-28-2006, 08:37 AM   #1
NitroMike
Active Member
NitroMike's Avatar
Neutral Safety Switch
I'm installing a neutral safety switch on a truck that did not previously have one. The switch itself is in the trans. (Keisler 5-speed) Any suggestions on the best way to wire it?
Thanks.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 10-28-2006, 09:27 PM   #2
NitroMike
Active Member
NitroMike's Avatar
Re: Neutral Safety Switch
Any thoughts?
Old 10-28-2006, 09:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
personally, i say remember to depress the clutch.
However, you could run the purple wire that goes from the ignition switch, run it to one of the wires on the switch, then the other wire on the switch, goes back out to the purple wire and on to the starter.
Old 10-29-2006, 01:33 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
just an idea here. get one from a 88-98 Chevy truck. its a simple pad type switch that get pushed by the pedal arm. I think it would be fairly easy to fab one of those in. a relay may be needed though.
68C15 is offline   Reply With Quote
Old 10-29-2006, 07:23 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I'm not familiar with that tranny but is it possible that the switch is a back-up light switch?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-31-2006, 06:22 PM   #6
NitroMike
Active Member
NitroMike's Avatar
No, the Tremec has a separate back-up light switch on the driver's side and a neutral safety (Ford-type) on the passenger side.
