Old 10-26-2002, 01:31 PM   #1
Tuffold72
th400 kickdown switch
I have given up trying to deal with getting the stock parts for my 72. Has anyone out there tried the Lokar kickdown switch set-up? Thanks for any info. By the way, great forum!
Tuffold72 is offline   Reply With Quote
Old 10-26-2002, 05:22 PM   #2
67 LWB
Smile kickdown
I have the B&M kickdown switch and it works pretty good. I got it because it is cheaper than the lokar but I think the lokar is a better one to have imo. If you want a pic of it let me know..
Devin
'67 C10 LWB FLEETSIDE, WEAK 305 , TH400, 3.73 REAR
COLORADO SPRINGS, CO.
67 LWB is offline   Reply With Quote
Old 10-26-2002, 06:23 PM   #3
Tuffold72
Yea a pic would be cool! Hey I am just down the road in the Albany area
Old 10-26-2002, 06:32 PM   #4
THOR 50
Over worked under paid
THOR 50's Avatar
Thumbs up easiest thing I've done to the truck
I have the Lokar set up, easiest thing I've done to the truck. A little pricey but just a small box the attaches to the trans. a cable to the carb. Connect to key on power, and plug into trans.
Sorry no pic.
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 10-26-2002, 07:18 PM   #5
67 LWB
Smile kickdown
here is the pic hope it works!
Old 10-26-2002, 07:31 PM   #6
photoglg
photoglg's Avatar
I used a horn button for the kickdown switch mounted on the floor. To kickdown I just step on the switch it works like a dream
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 10-26-2002, 09:19 PM   #7
Low67C10
I use the Lokar set-up , its nice but I had to drill a new hole in the throttle arm on the carb (edelbrock) to make it work right. When I used the stock hole for kick down it wouldnt kick down unless the throttle was almost wide-open. I drilled a new hole closer to the center of the throttle arm and now it'll kick down at about 80% throttle, much better.
No, Its not a 454
Low67C10 is offline   Reply With Quote
Old 10-26-2002, 09:54 PM   #8
Hooter
My other Love
Hooter's Avatar
I could never get that damn switch to work all i do now is drop it into second now
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-27-2002, 03:41 AM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Why couldn't you get the stock switch to work? The mounting bracket is already built into the pedal assy under the dash...The switch is only about $15 and two screws hold it on.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 10-27-2002, 04:54 AM   #10
COBALT
COBALT's Avatar
I managed to find one for a stock 327 2bbl setup. Not easy.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-27-2002, 12:30 PM   #11
Desert Rat
Desert Rat's Avatar
I have the earlier ones that mount by the carb using back Qjet hole operated by a tab that comes off the carb,i think it was 71-2 that had under the dash.I even have a couple from stock 69 Big Block 2bbl Intakes.
Desert Rat is offline   Reply With Quote
Old 10-27-2002, 05:34 PM   #12
jhow66
jhow66's Avatar
400 kickdown
Here is what you need. (see picture) If you have the original gas petal it will bolt right on. It will adjust itself the first time petal is pushed to the floor. To hook up just run one wire to fused switch on circuit and the other to switch on trans. The switch can still be purchased at dealers. Hope this helps.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-27-2002, 11:41 PM   #13
Hooter
My other Love
Hooter's Avatar
even with all of the wring it still wont work for me. It must be the soleniod in the tranny that is the only thing i can think of now
pictures of my life
