Old 11-03-2006, 10:51 AM   #1
b&a72
Active Member
b&a72's Avatar
Suspension difference
Was just wondering what the difference was between a 67-72 fornt suspension and a 73-87 front? The reason I ask is because I see alot of people switching. Is there a better ride, or is it just for disc brake reasons?
b&a72 is offline   Reply With Quote
Old 11-03-2006, 11:07 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Suspension difference
Disc brakes, rubber bushed arms and cheap, readily available parts. Other than that, basically the same thing.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-03-2006, 11:17 AM   #3
b&a72
Active Member
b&a72's Avatar
Another reason I ask is because my friend has an 81 and is running 20x10 rims on the front with no clearence issues, and I have 20x9.5 and I rub the a-arm should I switch to that style a-arm to fix it or is there a better fix?
Old 11-03-2006, 01:45 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Where is your clearance issue? Dimensions of the arms are very close between the early and late parts. Either of you running a drop spindle? This could be the difference.
-Chris
Old 11-03-2006, 01:52 PM   #5
b&a72
Active Member
b&a72's Avatar
Thats what I figured my rubbing is on the a-arm during a full right turn. But he running them and I am not that is probably the difference because it would lift the rim up higher. I knew it did not sound right because I know alot of guys running a 10" rim on the front.
Old 11-03-2006, 06:48 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Also depends on backspacing. What is his backspacing compared to yours? There is a 1/2" difference in total wheel width if they are the same, which equates to 1/4" more on the inside for his wheels. There's got to be a difference in backspacing.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-04-2006, 01:54 PM   #7
b&a72
Active Member
b&a72's Avatar
I don't know exactly but I will find out. At least they don't rub the fender.
