CS130 Resistor
This thread has been discussed on this site and a bunch of others but I've found conflicting info. Someone on this site said that the resistor needs to handle more than 3W. However on alternator parts.com it says Use a resistor of any value between 35 ohm, 5 watt, and 500 ohm. 1/2 watt. I had a 75 ohm 10 watt resistor that seemed to work but it was huge. The 3 watt 75 ohm resistor was large. I just bought a 1 watt 75 ohm resistor that looks about the same size as the one in the kit from madelectronics. http://www.madelectrical.com/images/image002.jpg
So, will the 75 ohm 1 watt resistor work? Thanks, Whit |
Re: CS130 Resistor
The one that MAD uses is 35 ohm 3 watt, metal oxide. I would think 1 watt might be pushing it.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Apr 2005
Re: CS130 Resistor
I found a light with the same resistance and ohmage and used it. I've got a nearly new cs130 alternator if you are insterested ($80).
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Oct 2006
Re: CS130 Resistor
I hooked up an alternator out of a 1997 pontiac(cs) on my 72 C20 without the resistor-I have a factory guage,and I havent had any problems charging. Can someone please tell me if I need to put the resistor in? And where?
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: CS130 Resistor
This website will tell you about the resister. The first part is the SI conversion and the second is the CS.
http://www.chevelles.com/techref/tecref14.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: CS130 Resistor
I just spoke with Mark at MAD and he says the resistor is a 75 Ohm 10 Watt metal oxide unit. It looks too smal to be a 10 Watt to me and he did say that he was going off of memory. He did however know the exact bulb number for a replacement of the factory dummy light, it's part number 194.
