11-10-2006, 01:40 AM | #1 |
under bed battery relocation
any one have pics of under bed battery relocation
11-10-2006, 01:53 AM | #2 |
Re: under bed battery relocation
ditto.
11-15-2006, 08:54 AM | #3 |
no one here done this before
11-15-2006, 04:41 PM | #4 |
It's a catastrophic success.
I put two either side of my ram and used heavy welding lead wire up the frame to the starter.If yours doesnt tilt you could make a box to mount to the frame.
11-15-2006, 04:49 PM | #5 |
I was just curious, does this require alot of time getting access to the batteries? Seems like a great idea, if they were still easily accessible.
72 GMC Sierra Grande |
11-15-2006, 04:50 PM | #6 |
A little Google came up with this.Mounted to the frame would work.
http://www.robinson-race-cars.co.uk/Battery%20boxes.htm |
11-15-2006, 04:57 PM | #7 |
i dont remember where it was.. maybe summitracing somewhere.. but i think theres a box that somehow flips down so you can get better access to it. that would probably be what i would go with.
-1947 3100 -1968 C10 -1970 K20 |
11-15-2006, 08:17 PM | #8 |
Here is a picture of my battery under the bed.
Of course I can raise my bed. The PO removed the wood bed and put plywood covered with astro turf. I'll change it back to wood someday, but I'll have to redo the battery and fuel cell.
71 Chevy Stepside 377/350 |
11-15-2006, 09:52 PM | #9 |
Here is a relocated battery box from CPP
http://www.classicperform.com/tech_a...attery-Box.htm Check it out |
11-15-2006, 09:57 PM | #10 |
Not mine
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
11-15-2006, 11:11 PM | #11 |
The diesel chevy vans have a frame mount under the---- drivers side? May be avail in the PnPs
11-16-2006, 02:25 AM | #12 |
that CPP box looks pretty cool... do you think the hooks would come undone on a big bump and the box falls off the tracks tho?
11-16-2006, 02:33 AM | #13 | |
11-16-2006, 03:07 PM | #14 |
It is a 16 gallon fuel cell. And yes it has a external fuel pump.
11-16-2006, 03:55 PM | #15 |
Heres mine
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
11-16-2006, 04:08 PM | #16 |
11-16-2006, 08:30 PM | #17 |
Sorry, thats the only pic I have. The backside looks just like the front side, except with some tabs on the side to bolt it to the frame. I just made it with some small angle iron, C-channel, and threaded rod.
11-16-2006, 10:36 PM | #18 |
Heres the one I built.The battery is mounted with 1/4" bolts through the plastic base of the battery in the flat spot between the cells. The battery is bolted in in this pic.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
11-17-2006, 08:14 AM | #19 |
