Old 11-12-2006, 09:02 PM   #1
70ChevyChris
70ChevyChris's Avatar
wheels
On my 70, the hubs on the front wheels stick out with the manual lockouts but the rears are flush with the drum.
I plan to mount 15x(8 or 10) rims with 33x10.5 tires after I lift 4 inches.
Are there any wheel caps or something of that sort to give the rear a similar look to the front?
70ChevyChris is offline   Reply With Quote
Old 11-12-2006, 10:35 PM   #2
qksilver
Re: wheels
that's because they are full floating front hubs. You could find or fit a full floating axle on the rear but they are usually 3/4 or higher
qksilver is offline   Reply With Quote
Old 11-13-2006, 12:34 AM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Re: wheels
I think he's really looking for the caps. depending on the wheel you are working with, they should have some type of center cap for it. Some even have a open center cap for the front too. I know mine did but the PO lost one of the rear caps. So I left the other rear off to match.
Warn used to make a kit for 12 bolt axles to make them a full floating axle, where you could also have a lock/unlock hub on the end just like the front. (good for flat towing or if you snap an axle) Good luck finding one of those as warn stopped making them a couple years back. A buddy of mine put a warn full floater on 9" in his early Bronco. Pretty cool, but pranksters at his job kept unlocking the rears on him when he was inside.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
