Old 10-30-2002, 11:12 AM   #1
ScottH
ScottH's Avatar
Stock coil spring question
Can anyone tell me if there is a difference in front coil springs between trucks with 6 cyl vs 8 cyl vs 8 cyl/ac? Thanks.
ScottH is offline   Reply With Quote
Old 10-30-2002, 12:30 PM   #2
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
i know theres a diff between small and big block v8s.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 10-31-2002, 10:21 AM   #3
ScottH
ScottH's Avatar
ttt
Old 10-31-2002, 09:51 PM   #4
bigvinnie
bigvinnie's Avatar
yeah there's a difference in the thickness of the steel rod used.... I did a 6 to smallbolck swap and the truck sat about an inch lower, which was ok but the springs were too weak, not stiff enough to provide decent stability.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 10-31-2002, 10:37 PM   #5
Fast68Chevy
Fast68Chevy's Avatar
actual load rating of them are same according to GM specs info,
std and then optional HD higher load rating up front by 100lbs, check it out in the specs sheets
Fast68Chevy is offline   Reply With Quote
Old 11-01-2002, 05:28 PM   #6
crazy longhorn
Fabricate till you "puke"
According to my local spring shop, the 6 cyl springs are lighter than the small block pcs. The info I was given was for aftermarket springs, but I was told they listed 3 different rate springs.......he sold me the lightest set(listed for 6 cyl), to cut down as they get effectively stiffer when they are shortened. Dunno what the GM spec says.......crazy AL
crazy longhorn is offline   Reply With Quote
Old 11-02-2002, 03:36 AM   #7
GMCPaul
Fast68Chevy is correct there was no difference at all between factory 6 cylinder front springs and factory small block V-8 springs they both received the same part # spring with exactly the same spring rate and height.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-10-2002, 03:41 AM   #8
Fast68Chevy
GM specs sheets say they are same
Old 11-18-2002, 02:53 PM   #9
Canada20
So would the HD 6-cyl springs be the same as the BB springs? Thanks,
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 01-24-2003, 08:57 PM   #10
rustedchevy
doubt it, probably would be the 100lbs heavier ones, HD ones
rustedchevy is offline   Reply With Quote
Old 01-24-2003, 11:13 PM   #11
Canada20
So they'd be even heavier than the standard BB ones? I'm getting a frontend from a '71 Longhorn tomorrow so I wonder which will be higher rate?
Thanks!
Greg
Old 01-24-2003, 11:15 PM   #12
rustedchevy
longhorn are on 1 ton chassis, and whether are HD or not wil be indicated on SPID label by either having HD rear springs listed or not lsited on the label, the weight ratings are listed in specs sheets
good luck Greg
Old 01-25-2003, 06:17 PM   #13
Canada20
Thanks for the reply!
Not to sound out of it or anything, but what's a SPID label? And which spec sheets should I be looking for? Seems kind od amusing that I might want to keep the springs out of my C20 with a 6 cyl because the BB springs from a C30 were lighter duty.....
Greg
