Old 11-13-2006, 07:01 PM   #1
wdsteeves
Cross member rivets
I have 3 cross members to remove.What is the best way to remove the rivets? Thanks
wdsteeves is offline   Reply With Quote
Old 11-13-2006, 07:16 PM   #2
msgross
msgross's Avatar
Re: Cross member rivets
get a $2 4" cutoff wheel and attach it to your hand grinder. Knicks em right off if you can get to em. punch the rivet out then with a hammer/chisel or air chisel.
msgross is offline   Reply With Quote
Old 11-13-2006, 07:46 PM   #3
ghetto_superman
ghetto_superman's Avatar
we torch em.. starting from the top of the rivet and blow it away... no damage to the frame.
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 11-13-2006, 07:47 PM   #4
ghetto_superman
and it involves fire- which is usually pretty sweet!
Old 11-13-2006, 07:53 PM   #5
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I take a grinder and cut an X pattern in the rivet, then use an air chisel and knock the head off. Then put a bull point bit in the air hammer and punch the rivet out.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-13-2006, 07:55 PM   #6
ghetto_superman
pretty good idea! i just always used the torch cause im a pyro... it would be much easier not to have to get that thing out every time i suppose!
Old 11-13-2006, 08:29 PM   #7
roj2323
i've done it 3 ways and by far the easest is an air chisel. a bit that looks like a wood chisel "flat on one side with about a 30% angle on the other side." granted a torch is faster but also more dangerous to yourself and the frame if you don't know what your doing. i've also had great luck with a grinder with a 40 grit flap disk.
ondrew
roj2323 is offline   Reply With Quote
Old 11-13-2006, 08:49 PM   #8
Shane
Shane's Avatar
Same here ... X with a Zizz wheel and then the ol' cold chisel and a big a$$ hammer!
Haven't found one yet that wouldn't come out using this method. Although some require a larger hammer than others.
Shane is offline   Reply With Quote
Old 11-13-2006, 09:33 PM   #9
SanitysBane
When in doubt, get a bigger hammer.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 11-13-2006, 09:37 PM   #10
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
on my 69 some jerk took a torch and cut the 3 spd crossmember out of it leaving part of it on the frame still with the rivets attached, why he didn't just blow off the rivet heads i do not know but thats something left for me now
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 11-13-2006, 09:49 PM   #11
leftcoast66
leftcoast66's Avatar
I did that on mine because I didn't want to get too close to the fuel lines which run inside of the passenger side of the frame if I remember correctly(haven't seen the truck in 4 months). Now that I read this thread I'm gonna go and cut them out with an airchizzle and a grinder, cuz I didn't know that method at the time.
leftcoast66 is offline   Reply With Quote
Old 11-28-2006, 03:11 AM   #12
ghetto_superman
its actually pretty surprising how many ive seen done like that..
Old 11-28-2006, 04:50 PM   #13
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Im about to do this. I think Ill use the X method with an air hammer and cutoff wheel.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 11-28-2006, 05:34 PM   #14
Jeremy536
I have found that an air chisel can be the quickest and easiest way.
Jeremy536 is offline   Reply With Quote
Old 11-28-2006, 08:57 PM   #15
SCOTI
SCOTI's Avatar
Try getting to those top rivets on that crossmember & you'll know why some people just cut it off flush w/the frame rail. You won't get a cut-off wheel or air chisel in there & not everyone has access to a torch.
On the few trucks I've done, if we didn't have a torch & the truck was completly assembled, we just cut the c.member flush w/the frame so that it was out of the way.
If the body was off, we removed all rivets & pieces completely.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
