Old 11-13-2006, 09:17 PM   #1
roj2323
700r4 shift linkage
yea yea yea i know another 700r4 question. so i have my 700r4 installed in the truck now but i can't seem to make heads or tails of the shift linkage. the other thing is the stock auto linkage is going to drasticly interfear with my new exhaust "dooles". idealy i'd like to use a shift cable but i'm having trouble finding a viable solution. anyone have any ideas?
ondrew
roj2323 is offline   Reply With Quote
Old 11-13-2006, 10:59 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: 700r4 shift linkage
I used a shift cable from Advance Auto from B&M. They had it in the store to. Don't remember the part number though. I had the orignal one and took it with me to match length.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-13-2006, 11:18 PM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I bought a Lokar Column Cable Shift Linkage and it works great. I ended up not using the column bracket that came with the kit... It interfered with my brake booster so I trimmed the linkage tab down and fabricated a bracket that mounts on the frame to hold the cable in place.
http://www.lokar.com/interior_pages/colshiftlink.htm
Let me know if you need any more info or some pictures of my setup.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-14-2006, 01:03 AM   #4
Greubin
Greubin's Avatar
I used the Kugel Components shift linkage from ww.700r4.com ( bowtie overdrives ). Easy to setup and adjust, direct fit w/ no trimming in my application.
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
Old 11-14-2006, 09:56 AM   #5
roj2323
c10-driver pictures would be really cool. i'm really surprized something seemingly so simple could stump me like this. thanks
Old 11-14-2006, 10:52 PM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I included the best pictures I could find, I hope the are good enough to give you an idea how it works.
Here is a picture from the Lokar website. You will need kit # ACA-1804 or 1805 depending on the diameter of your column (probably 2", ACA-1805). I believe the kit was only $120. Pretty cheap in my opinion.
The aluminum bracket included in the kit is attached to the column and holds the cable in place up top. On the transmission, the brackets included in the kit bolt on using a couple of pan bolts.
There is also a semi-circular bracket linkage included in the kit that mounts on the column shifter tab that sticks out the side of the column. The purpose of this "linkage" is that, with our trucks, the linkage is connected on the right side of the column (closest to the engine). The difference between the cable and a direct linkage is you need to turn a push into a pull to shift the gears. This "linkage" is bolted onto the shifter tab then attached to the cable.
As I mentioned in an earlier thread, I didn't use the bracket because it was a little tight to the newer style booster I was using. Instead, I fabricated a bracket that mounts to the frame as shown in the pictures below.
I have my truck disassembled for a restoration so I will not likely be able to get more useful pics. Please let me know if you have any more questions.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 11-14-2006, 11:34 PM   #7
roj2323
thanks c-10-driver thats what i needed.
Old 11-10-2007, 12:58 PM   #8
Richard H.
Spanked once
Richard H.'s Avatar
Thanks for the link C10-Driver , been wondering what to do about my back up and safety switch!
Richard H. is offline   Reply With Quote
Old 11-10-2007, 02:25 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Little pricey, but I like floor shifts and clean columns.
Just another option....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-10-2007, 03:08 PM   #10
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
If you're talking about the neutral safety switch it mounts on the column as it normally would. The Lokar kit I used doesn't change anything to do with the column itself, it only replace the mechanical link between the column and the transmission.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 11-10-2007, 03:34 PM   #11
70C10Step
70C10Step's Avatar
Thanks C-10 driver I just ordered the kit from summit racing, I was wondering what i was going to do, for $49.95 I do not think I can go wrong...
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
