Old 10-30-2002, 10:28 PM   #1
Don Smith
Flexplate Bolts
I am installing a flexplate on new engine using ARP bolts. I notice there is a slight amount of clearance between the holes and bolts and you can rotate the flex plate a fraction of an inch back and forth with the bolts only finger tight. Is this clearance normal?
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 10-30-2002, 11:08 PM   #2
crazy longhorn
Fabricate till you "puke"
yes, this is normal as the holes in the flexplate are slightly larger than the bolts
crazy longhorn is offline   Reply With Quote
