Old 11-16-2006, 08:28 PM   #1
"67"StepSide
Junior Member
"67"StepSide's Avatar
Exclamation Big block oil pan
I'm putting a big block in my 67 stepside I'm wondering how big an oil pan will fit with out hitting the crossmember? It's a stroker so the bigger the better, I'm thinking of a moroso ultimate II. I just don't know if it will fit? Also has anyone ever put a dry sump system in these trucks?
"67"StepSide is offline   Reply With Quote
Old 11-16-2006, 08:57 PM   #2
qksilver
Re: Big block oil pan
Dry stump is big bucks. If you want more clearance swap in a 73-86 crossmember, it will give you some more room and more oil pan options
qksilver is offline   Reply With Quote
Old 11-16-2006, 10:04 PM   #3
"67"StepSide
Junior Member
I have a dry sump for it I just didlen't think it would fit with the pump. I did not know 73-86 fit what's different?
Old 11-16-2006, 11:13 PM   #4
69CvyPickup4x
69CvyPickup4x's Avatar
I have a moroso deep pan on my 454, I dont know what crossmember this is out of I cant say for sure because when i bought the truck it had this crossmember, but it was cut in half right down the middle..so i bent some metal and patched it. It has the early model motor mounts. here it is:
69CvyPickup4x is offline   Reply With Quote
Old 11-17-2006, 01:03 AM   #5
Rick Mills
Rick Mills's Avatar
I have a Moroso 6 qt. pan on my big block with no modifications to the cross member. Had to pull the motor to put it on though.
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 11-17-2006, 01:51 AM   #6
clay68c10
clay68c10's Avatar
I have a kicked out sump 8qt ebay pan on my 454 and it clears the original crossmember.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-17-2006, 08:06 AM   #7
"67"StepSide
Junior Member
Thanks for the input guys! Clay do you mean you have this oil pan on ebay now? or you got it on ebay? Does any one else have pictures of there big block pan in the truck with stock crossmember? I'm looking to see how big a kick out I can get on it with out hitting crossmember....
