Old 11-19-2006, 11:50 AM   #1
grayw0lf
Oops! What did I mess up now?
I finally removed the bed & was cleaning up the frame & such with a wire wheel on a 4.5" grinder. When on the rear end I came across this.
There are apparently about 6 of these little spots that appear to be welded. Unfortunately, I found 2 of them after the wire wheel ate through them.
What are they for? How should I close them up? Is it just to keep the elements out & I should use RTV? Or do I need to MIG them back shut?
If MIG, do I need to drain the pumpkin first?
Thanks,
John O>.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-19-2006, 12:06 PM   #2
long69
Re: Oops! What did I mess up now?
jb weld should do the trick
long69 is offline   Reply With Quote
Old 11-19-2006, 12:10 PM   #3
cdowns
cdowns's Avatar
i think they maybe rivet heads to keep the tubes in place during assembly// i'd take a piece of wire and see how far you can push it into the hole if it comes out wet ,it will leak if it doesnt go in far less than 1/4inch nothing to worry about
Old 11-19-2006, 12:40 PM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
GREAT WORDS TO LIVE BY!!!!!!!!!!!!!!!
72freak is offline   Reply With Quote
Old 11-19-2006, 01:10 PM   #5
krue
Designated A-hole!
krue's Avatar
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-19-2006, 01:34 PM   #6
roj2323
they're just gas pockets from when the tubes were welded in. i welded mine in with no issues but JBweld would work just as well.
roj2323 is offline   Reply With Quote
Old 11-19-2006, 07:55 PM   #7
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
its just welding slag or as said before a gas bubble when the tube was welded in, seeing as that the tube goes in about 2-3" past that with a +.005-.010" fit i woulndt sweat it leaking , that is unless you think you are bo duke and jump the local river once a day.
trkklr77 is offline   Reply With Quote
Old 11-19-2006, 08:51 PM   #8
grayw0lf
Thanks for the good info. I think JB Weld will do the trick.
John O>.
05' Dodge Neon
94' Seadoo SP
