anybody every rebuilt a 4 speed saginaw?
took my truck to the dragstrip this weekend and blew up the 4 speed saginaw in when i hit 3rd gear. not a gear left in the thing so i had to get towed home. i haven't pulled the side cover off yet cause its been kinda cold and my parents kicked me off their insurance so im in no hurry to get it fixed. something tells me this one is way beyond saving thought. i do have another one sittin in my garage that needs a new front bearing, scyrnoizers, and a good cleanin to get all the meatl crap out from when the frint bearin went out. that gets me to my question. anybody ever rebuilt one of these and any advice or does and don'ts if you have. in case yall were wondering, 10.357 @ 72.16 mph. its 1/8 mile. thanks. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
Re: anybody every rebuilt a 4 speed saginaw?
Yeah I have rebuilt them. But if your going to be drag racing the truck i would suggest a different trans, Like a muncie or an aftermarket Richmond, tremec. Something of that nature.
As for rebuilding. Lay everything out in the same order you take it out. Then you can put it back in the same order. Easiest way I know to tell you, rather than showing you. |
![]() Join Date: Nov 2006
those are notorious for being weak trans.... if you gonna drag bite the bullet and get a aftermarket trans made for what your going to use it for. stay away from aluminum cases too. the hemi 4 speed is a good strong trans. want one ? 1750.00 plus shipping. bob
i know i need to get a better one but im on a pretty tight budget. i thought it could handle a 305 in street tires. reckon not. i'd like to get a muncie but don't have the moeny rite now and need a cheap fix. its my daily driver. thanks. chris.
put the old trusty 3 speed in it.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
if i hadn't have traded in my 2 old 3 speeds to get the the second 4 speed i have i would, but its a little too late for that. chris.
#8 | |
even if you had the three speed i wouldn't put it in if you were gonna drag it because it would lock up the second you try to powershift it
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
Fabricate till you "puke"
I have rebuilt a chit load of those old saginaw's, & will say they are pretty easy to work on if you are a patient person. The biggest problem, is broken gears.....they cost more bucks to fix than they are worth! Afew yrs back, I blasted 3rd gear @ 6500 in the old longhorn, & took that old saginaw 4 spd out. My youngest "brat" , ridin with me at the time said"Dad you blew the engine"......My response was ..."Nope it was the trans". It sounded like a machine gun went off under that truck, took all the teeth off the input shaft , & the counter gear! The kid says " what do we do now Dad"? We gonna row this BIOCH till we find a gear that still works....& drive the FU@# home
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#11 | |
i've got a hurst cometition plus shifter in there know and all i have to do to make it work on a 3 speed is take off the reverse linkage rod and not look at what the ball says. but i like the 4 speeds a whole lot better than 3 speeds. more fun. i was shiftin the shiznit out of it when it blew. chris.
67-72 parts finder
why not just switch it to an automatic? cheap and easy to build for the drag racing
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
senior member
if you do rebuild this would you mind letting me know where to get hard parts for these trannys maybe its a canadian thing but i cant find any of them and i have to keep buying new trannys and hoping there good
69 GMC bagged |
#15 |
its my daily driver and i only got the track a couple times a year. and i love slammed threw the gears so no. but as much a i hate to admit it, automatic would be better from racing, whole lot easier off the line. chris.
#16 | |
http://motors.search.ebay.com/4-spee...w_W0QQfromZR40
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's Last edited by 71chevytruckguy; 11-20-2006 at 10:47 PM. |
#17 |
I also had one blow out on me just idling up the road. Went from second to third and coplam!!!! ract tact tat. Knock knock. Well you get the idea. But I also had a 4spd saginaw in my Nova I used to own. The motor was a worked over 350 dynoed at 435 hp 3.42 gear posi . one BAD AZZ ride. But I learned if you don't have the shifter linkage adjusted JUST right your asking for trouble. And another thing is on that last 4spd. I MADE sure I had it in gear before I let the clutch out. And no power shifting. No dumping the clutch to get the tires a smoking. So more advice, Don't drive it like you stole, till it's in your budget to get a good auto or better stronger manual trans.
#18 |
last I checked a new saginaw cluster gear was in the $400. range.
