Old 11-20-2006, 08:41 PM   #1
72 longhorn BB
72 longhorn BB's Avatar
need O.E pictures of harness routing on 72 BB 402
Hey there, do any of you have pictures of the following?
- Negative battery cable routing to block
- Positive battery cable routing to starter
- Location of horns
- harness routing across top of engine (rh and lh sides)
If you can supply any or all of these pictures it would be greatly appreciated.
I had my rig apart for years and forgot exactly where everyting went.
Thanks ahead of time and keep the pictures coming. They all tell something.
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 11-20-2006, 08:57 PM   #2
Bob Moore
Re: need O.E pictures of harness routing on 72 BB 402
I can answer the horn question. Single horn mounts on the core support in a weld nut on the left side of radiator and down low. The 2nd horn mounts further out on the core support in a weld nut near the headlight. Thgese are both on the engine side of the core.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-21-2006, 08:25 AM   #3
72 longhorn BB
Thanks, I found the mounting point by the headlight, but not the one by the rad support.
Also, the cable routing to the starter and block are important.
Has anyone got a few pictures to spare?
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
Old 07-17-2007, 10:05 PM   #4
72 longhorn BB
Hello Bob, a while back you answered me about locations of the horns on a two horn setup. You mentioned the driver side rad support for the second one. I am not sure if you ever sent pictures, but based on the location you described, there is no provision for that on my rad support, yet I KNOW I had two cus the wiring harness is wired for it. could I ask youthe favor of snaping a picture of your two horn setup and shoot it to me at chuck_rummler@wideopenwest.com
thanks ahead of time
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
