Old 11-02-2002, 08:42 AM   #1
Blaze69
Blaze69's Avatar
Red face Bringing my first love back on the street
Hey all,
Getting ready to pump some life back into my '69.
Any suggestions as to things I may need to check. It's been a little over a year since there's been any fire coming out of her tailpipes. I've done alot of things to get her ready, just give me a few ideas that you think I might have missed before the big day comes
Well, wish me luck.
Blaze69 is offline   Reply With Quote
Old 11-02-2002, 10:53 AM   #2
Blaze69
Blaze69's Avatar
Beuller.........Beuller........Beuller.......anyone.......
Old 11-02-2002, 11:17 AM   #3
Bowtie468
Bowtie468's Avatar
Blaze, lets see.... How about the braking system. Check for any leaks at the wheel cylinders and make sure everything is free and operable. Ummm.. Grease everything up real good ,steering,suspension, u-joints. I'm guessing that you have put fresh fuel in it. Condition of tires, shocks. Correct operation of all electrically operated componants. Cooling system- flush entire system. Change radiator cap or just check if you have the means to do so. Replace thermostat. Check condition of hoses. Well, in general, just check everything!! Good Luck
Bowtie 468
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 11-02-2002, 11:19 AM   #4
Bowtie468
Bowtie468's Avatar
Oh, and one more thing. Dont forget to prelube the engine before firing it up.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 11-02-2002, 11:26 AM   #5
Blaze69
Blaze69's Avatar
Thanks for the stuff, so far i've done most of that. I did have a brain fart and left the gas in waaaaaaay too long. Took me awhile to get it all out.
BTW,what's the best recommended way to lube the engine.
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock.
The front end disc swap is finally complete
2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out.
Old 11-02-2002, 11:29 AM   #6
Blaze69
Blaze69's Avatar
What's with my envelope having that dot on it? Is it an eye that's watching me? Stop it! It's driving me insane!! Have I been gone that long????:p
Old 11-02-2002, 01:11 PM   #7
Dandeluxe
Dandeluxe's Avatar
fire up ?
i suggest you shoot some marvel mystery oil in each spark plug hole and put a long screwdriver down the distributor hole and prelube it with a drill driver. also check all hoses for dry rot. just my 02 cents
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 11-06-2002, 11:30 PM   #8
Blaze69
Blaze69's Avatar
Well , let's see. I finally got my Blazer to start up whoooaaaa! now that took some time. I took apart my carb and thought I had cleaned it all out-----NOPE. Forgot to check one place, and wouldn't you know it, it wasn't getting any gas. Took care of that and it fired right up. Smoked out the hood for awhile. But who cares my machine was up and running.
Next I found out I didn't have any fluid in the tranny (took 3 1/2 quarts). After adding that it moved just fine. The brakes seemed a little locked and the inside was dusty as hell.
So I parked it in the shade on some level concrete. and gave it a good rinse down, the washing will come later.
Things to do:
1. address the tranny fluid leak and change filter and fluid.
2. Change the oil and fluid in front and rear dif. and lube chassis
3. Change the antifreeze out.
4. Flush the brake system.
5. I think I may drop the tank and clean it out, I need to replace the filler hoses anyway.
6. Change over to an internal alt.
7. Change the front drums to disc, donor is an '85 blazer.
and last but not least..........Give it a good cleaning inside and out.
As a matter of fact, it doesn't even sound as though it's been sitting for a while. Lucky me, I guess.
