11-26-2006, 09:24 PM | #1 |
Question for 68 pickup owners...help!
Does anyone have a picture of a factory 1968 firewall on the driver's side? I am in the process of shaving my firewall but can't remember what all the holes on the driver's side go to. I have three holes, one is speedo and a second is oil pressure. Can't figure out the third. Please help!
Thanks Dan |
11-26-2006, 09:34 PM | #2 |
The Older Generation
Re: Question for 68 pickup owners...help!
11-26-2006, 10:10 PM | #3 |
emergency brake cable?
11-27-2006, 01:04 AM | #4 |
Lock Doc thanks for the thread, however, the pic is for a 72 and very different. Qksilver the E-Brake is a rectangle on the bottom of the cab, i found that one thank goodness.
11-27-2006, 12:59 PM | #5 |
Do you still have questions? Size and location would help.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
11-28-2006, 09:38 AM | #6 |
Yes I still need help. The three holes I mentioned are on the very driver side of the fire wall. they are above the sqaure hole for the wiring block. One I believe is for speedo, and I'm guessing one could be for a choke?, and the third I'm lost on. Thanks for the help!
11-28-2006, 09:54 AM | #7 |
Java Mechanic
I have a 68 C-20 ... but I'm at work... I'll have a look when I get home.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
11-29-2006, 06:12 PM | #8 |
Java Mechanic
Here is a picture of my firewall:
The black cable that is going nowhere is the choke.
11-29-2006, 06:42 PM | #9 |
Mine has three holes left of the wire block, lower is for my Tach wire, middle is speedo, top is plugged off. Then there is a small hole above the block that has a rubber nipple in it (no idea on that one). My oil pressure goes in on the back side of the hump, along with manual throttle.
11-29-2006, 09:47 PM | #10 |
thanks guys, looks like everything but the oil pressure and the speedo is getting the electric treatment.
