Old 11-26-2006, 09:58 PM   #26
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: 73+ front end conversion
uh, its a completely different setup
you can very easily put a 73-91 axle in the front as they ALL have disc's
trkklr77 is offline   Reply With Quote
Old 11-27-2006, 09:30 AM   #27
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Originally Posted by Parkerkl View Post
is this swap just as easy for the 4x4 s, would like discs up front for my 68 k20
This should be a very easy swap. One route would be to get parts from a donor. Tear off all parts from the king pins out, including the stub axle.
Another method would be to replace ANY front axle assembly from a 73 to 91 truck, blazer, or surburban. You will have choices of the GM Corporate 10-Bolt, Dana-44, or even a Dana-60, but watch your gear ratios, they're typically 3.73:1 ratios, but some do have a 3.54:1 ratio, as well as a 4.10:1 ratio.
mtndewmaniac66 is offline   Reply With Quote
