Old 11-29-2006, 01:25 PM   #1
Aarons72s
A/C high speed blower relay bypass?
Has anyone ever bypassed the high speed blower motor relay? I am sick of blowing them every 12 months. ANd only having low and medium speed. Why did gm even use this anyway? The heat trucks dont use one and from what I can tell they use the same blower motor, except the a/c one has a larger case and a hole for a vent tube. So why shouldnt it be hooked up like the heat blower? If someone has done this could you please describe what you did. And if no one has I will try it myself and post the results. Thanks again.
Aarons72s is offline   Reply With Quote
Old 11-29-2006, 01:38 PM   #2
mrein3
mrein3's Avatar
Re: A/C high speed blower relay bypass?
I converted my truck from non-AC to AC.
They factory relay was on the behind the glove box stuff box I bought but I still rigged up my own. Here is what I did.
I took the wire from the fan switch that is hot when you want high-speed. I made this a control wire to a bosch style relay. Right from the positive junction block on the RF fender I ran a 10 or 12 gauge wire to the relay. I put a 20 amp fuse in this wire, under the hood, on top of the RF inner fender for easy access. Then from the hot when energized prong on the relay I ran 10 or 12 gauge wire to the fan.
I use the same relay for hi beams, low beams, hi-speed fan, and driving lights. I keep a spare in the glove box. I had one fail a while ago but that was because my truck was parked outside that winter and water was dripping on the relay around the hood. I moved the relay to a dry location and no longer have a problem. (That was a headlight relay. The fan relay is screwed on to the heater ducts).
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-29-2006, 01:45 PM   #3
Aarons72s
Cool thanks mrein3. Yah the stock relay leaves much to be desired. I might try that. Try to see what my options are. Before wasting time and money on another one of those stock relays. Thanks again.
Old 11-29-2006, 03:15 PM   #4
neonlarry
neonlarry's Avatar
I would run some kind of relay, the stock switch can barely handle the slower speeds.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-29-2006, 07:36 PM   #5
jacobs
jacobs's Avatar
Don't bypass the relay. Years ago, I installed an AC fan from the junkyard after my old fan motor quit. Shortly afterward my heater switch burned out due to the increased load. I then installed a relay and a new heater switch and it's worked great ever since.
jacobs is offline   Reply With Quote
Old 11-29-2006, 08:28 PM   #6
mrein3
mrein3's Avatar
What I did is replace the factory relay with a newer style one.
If you try to run the fan on high with just current through the switch and not a relay you'll burn it up for sure.
One thing I noticed when I was collecting parts is that the fan switch on the heater control I bought and EVERY switch in the junk yard I looked at showed some signs of melting. I bought a new switch, a new connector, and used factory style contacts in the connector. I'm pretty sure my system will outlast factory wiring.
'72 Malibu hard top
Center City, MN
Old 11-29-2006, 08:34 PM   #7
Aarons72s
Ok so how about another option, run a heater blower motor? they will bolt right up, I got a a/c blower on an heater box. How about that as an option?
Edit, i have seen alot of melting when those motors start going out, when they start going out they start eating some serious voltage.
