Old 11-30-2006, 08:39 PM   #1
mrnascar38
71 front drive shaft ???
I am trying to finish up my 72 Blazer and I am missing the front drive shaft. Did the 71-72 blazer have a cv yoke style like the late 70's or should I be looking for something else? Pics would be great. Thank you
mrnascar38 is offline   Reply With Quote
Old 11-30-2006, 10:01 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 71 front drive shaft ???
Various shafts are available, does it have any lift to it?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-01-2006, 12:47 AM   #3
jhow66
jhow66's Avatar
What kind of transfer case?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-01-2006, 02:06 AM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Mine has a NP205 and the drive shaft is CV style. It's also stock with no lift if that helps.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-01-2006, 08:03 AM   #5
Blazer1970
Blazer1970's Avatar
The 72 would have used a Spicer double cardan joint which uses a yoke on the transfer case output. Sometime in the mid/late '70s GM changed to a Saginaw double cardan which uses a flange on the t-case output.
Blazer1970 is offline   Reply With Quote
Old 12-01-2006, 11:02 PM   #6
jhow66
jhow66's Avatar
The one I have came off a Dana 20 with a 3 speed manual.
Old 12-01-2006, 11:44 PM   #7
Southedisto
River life......
Southedisto's Avatar
If you need them, I can get you pics and measurements tomorrow.
Southedisto is offline   Reply With Quote
Old 12-03-2006, 07:38 PM   #8
mrnascar38
My blazer is not lifted and has a 205 transfer case, by the looks of it I need a driveshaft with (double joint) that connects with a u joint/yoke. Is this a difficult driveshaft to find? What year/models GM products should I look for it on in the junkyard??
Old 12-03-2006, 07:51 PM   #9
krue
Designated A-hole!
krue's Avatar
Keep an eye on the parts board, they show up fairly often. Should be the same ds for truck/blazer sense the engine/trannies are mounted in the same place with regard to the front axle.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-06-2006, 10:07 PM   #10
69TowRig
My truck has the Saginaw 3-speed/Dana 20 combo, and I bought it without a front shaft. I bought a used one from a truck with a 465/205 combo and it fit no problem, so that tells me that the 67-72s with either drivetrain should fit fine.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-15-2006, 11:31 PM   #11
Pyro 72K5
I have a 72 Blazer. I removed the old cv yoke and had the drive shaft made longer and put in a normal u-joint. I do not have sespension lift and the angle worked out fine.
PYRO 72K5
Pyro 72K5 is offline   Reply With Quote
