Old 12-02-2006, 02:46 AM   #1
Rebeltilldeath3
Advantages of replacing throttle body?
My best bud came home from the Army today
Anyway, after shooting the **** for a little while, he insisted I jump in his Blazer and go for a spin. Long story short, it suddenly has balls and big ones at that. The motor has really woken up. He says his old man put a new throttle body on along with a spacer. The injectors are fairly new as well, they were replaced in June I believe.
Would replacing a throttle body really make that much of a difference?
Rebeltilldeath3 is offline   Reply With Quote
Old 12-02-2006, 12:07 PM   #2
us111
Re: Advantages of replacing throttle body?
hello,,it can make a big difference in certain case's.had one that was running like crap,tried everything,took the t-body off,replaced ran like a champ,,had already had it off a couple times but never noticed a hair line crack from one of the bolt holes that ran clear into the bore,,was sucking air bad..
us111 is offline   Reply With Quote
Old 12-02-2006, 02:02 PM   #3
Rebeltilldeath3
I was just wondering, because I know his old man is a trickster. He'll tell you he did one thing, just to cover up what he really did.
Old 12-02-2006, 04:47 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
LOL, thats great. I know it will help but I don't know about getting major balls from doing a new throttle body and a spacer, should definantly pick up the pace but it might also have really needed a new throttle body in the first place so doing it might have helped more then it usually would.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 12-02-2006, 04:53 PM   #5
Rebeltilldeath3
Well by major balls I mean running like a fresh V8 should. It was a dog before, and mine still is.
Old 12-03-2006, 07:10 PM   #6
66skylarkpost
66skylarkpost's Avatar
did he replaced it with a rochestor or a holley ? i bought a holley replacement 670 cfm a couple years ago for my ' 89 silverado with a 350 .i cut out the intake manifold bores and added a helix spiral spacer and it woke it up .yet i modify the bracket for the cables to raise them up an inch and get fuel line extensions ,but it was all worth it. like its a totaly different motor. i also bought a air intake kit i use in the warmer months and then the stocker with a jegs air tube in the winter. the holley's have also a different regulator and injectors over stock .i believe, correct me if i'm wrong , the stock body is rated 390 with 1 5/8 " bores . where the holley ones have big 2 " bores same as the stock 454's . just after that i bought a 3" cat back exhaust kit( where i have three inch pipe where the cat should be ) , it works out real nice . by the way , i have an accel coil and ignition module
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 12-03-2006, 07:12 PM   #7
66skylarkpost
second pic of bracket
