Old 11-05-2002, 03:12 PM   #1
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
Unhappy bed mounts
does anyone know where i can get repro bed mounts? i'm looking for the front mounts onthe fram just behind the cab. i had to cut them to get the bed off. any ideas? also anyone know where i can get whole repro longdeb panels? thanks
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 11-06-2002, 11:18 AM   #2
yellowgmc
yellowgmc's Avatar
anyone?
1972 GMC 1500
1994 F-150 XL 4x4
Old 11-06-2002, 11:27 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
find a local goodmark dealer for the bed sides. I believe Early Classics sells them. I would look on the parts board or contact guys like Wes to see if you could find some good clean originals. If you are talking about the bolts and bushings for the bed mounts almost any of the vendors on this board can get you those. I bought mine from Chevy Duty.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-06-2002, 12:34 PM   #4
yellowgmc
yellowgmc's Avatar
i'm looking for the actual upside down u shaped metal mount that attaches to the frame. the pic i attached isn't up close but i need the mounts that are right behind the cab. you can kinda see where i had to cut the old ones.
1972 GMC 1500
1994 F-150 XL 4x4
Old 11-06-2002, 01:57 PM   #5
crazy longhorn
Fabricate till you "puke"
Im not sure you can get that bracket new, but a trip to the boneyard should get you set
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-06-2002, 04:50 PM   #6
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
i think most of the vendors sell those items, check chevy duty and some others but i coulda swore.... (crs might be kicking tho)
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 11-06-2002, 04:52 PM   #7
1971Stepside
Almost Satisfied
I have not seen those reproduced. I bet you will have to find a donor truck. Grind the two rivets off and they are yours.
Old 11-06-2002, 07:09 PM   #8
TxGary
TxGary's Avatar
yellowgmc, sent you PM on the brackets.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 11-06-2002, 10:13 PM   #9
Huck
Huck's Avatar
Anyone parting out trucks should be able to fix you up with a couple of good bed mounts. As far as bed sides, don't believe anyone is making the long bed sides---just the short fleet sides.
Good luck
Huck is offline   Reply With Quote
Old 11-06-2002, 10:45 PM   #10
Kid
Kid's Avatar
I think I still have mine I took off when cutting my frame. You can have them for the cost of shipping if you want them.
Kid is offline   Reply With Quote
Old 11-06-2002, 10:50 PM   #11
MOTHERTRUCKERS
I have them in stock, sandblasted and primed for short or longbeds.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
