Old 12-10-2006, 07:05 PM   #1
Als454
What's wrong with this picture?
Is this choke hooked up correctly?
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 12-10-2006, 07:14 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: What's wrong with this picture?
take a bigger picture so i can see the choke plate
looks like you got the incorrect choke spring if thats where it sits cold,
the loop that holds the rod should be closer to the manifold..
right now it would be in the center of travel
rage'nrat638 is offline   Reply With Quote
Old 12-10-2006, 07:14 PM   #3
john
member #16
john's Avatar
I think you have the wrong thermostatic spring. Mine is wound the opposite way with the rod to the front side. They make different types of springs.
john is offline   Reply With Quote
Old 12-10-2006, 07:16 PM   #4
rage'nrat638
heres a picture..
i will go take a picture of the correct coil cold
this coil is at 65 degrees in the garage
Old 12-10-2006, 07:27 PM   #5
rage'nrat638
i know this is a little late but this is my new carb to get rid of the old coil type choke
this is a hot tube choke carb converted with a edelbrock electric choke conversion kit
Old 12-12-2006, 08:13 PM   #6
rage'nrat638
i found it....i got a box of carb parts.. more than likely have the correct spring.
i will go look...
Old 12-12-2006, 08:32 PM   #7
rage'nrat638
heres the correct brand new choke spring..brand new..
it's called a devorced choke spring
