Old 12-12-2006, 11:24 PM   #1
justn84
justn84's Avatar
GM gov-loc advice
I recently bought one of these units at a swap meet for 50$.I have been shoping for gears as of lately and every time i mention it peoples responses are "oh that peice of crap".so what is the real deal your honest opinion on the GM gov loc is it any good?
Thanks Justin
justn84 is offline   Reply With Quote
Old 12-13-2006, 12:00 AM   #2
lurch115
lurch115's Avatar
Re: GM gov-loc advice
some more details might be a little better.....are you talking about a locker from gov. trucks, or out of the police interceptor cars
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 12-13-2006, 12:11 AM   #3
justn84
justn84's Avatar
not shure about it at all,I know gov stand for the method of oporation
It is one of the factory postrac units. its for a 10 bolt
looks like this
Old 12-13-2006, 01:03 AM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
I've gathered from the general consensus around here that the GM Gov-Loc units are not that great. I think it has something to do with the harshness of the "lock" part of operation I would assume that if you are driving on the street and you don't have a high-performance truck, it would work fine.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 12-13-2006, 02:23 AM   #5
Russell
Professional Grade
Russell's Avatar
The Gov lock in my 14 bolt has outlasted 3 trucks now, and still locks up just fine.
Thats a 14 bolt though, 10 bolts arn't quite as tough...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-13-2006, 03:10 AM   #6
edman87
junk collector
It is not the harshness of the locking that makes them junk, it is the lack of locking. The 14 bolt units are better, but not suited to harsh use.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 12-13-2006, 09:44 AM   #7
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The GM Gov Lok is a misunderstood piece by many people. It's not a locker at all and doesn't operate harshly. It's a clutch type posi unit that only actuates under a certain speed (around 30 mph but depends on tire size since the posi goes by ring gear rpm) (hence the gov or governor part of the name). They did this to prevent side slipping when a posi actuates with one tire on ice at highway speeds.
Just like other clutch type posi units, they do wear over time and lose the ability to hold torque. I've had a couple and had no problems with them. I talked to Randy's Ring and Pinion about them, they said the biggest problem with them was that when they failed, they tended to take out every other part in the differential. I think this is where they get their bad reputation.
GM still uses this design in their new trucks and even behind the Duramax so I don't think it can be all bad...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 12-13-2006, 10:23 AM   #8
hiway
Mad Scientist
I agree with the "when they fail they take out everything in the diff" part. They will...I even ended up with a hole in the cover. Don't hot rod them or jerk them around to much.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 12-13-2006, 01:27 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The reason most people say that is because of hearsay. They knew someone that had one that grenaded, or they knew someone that knew someone.......
For a daily driver there is absolutely nothing wrong with them. They work just like ElGracho described and they work well.
They are designed to engage both wheels under slippage. They are not designed for full throttle assault (wide open throttle in a rock crawler, mud, snow, ice,…think finesse). They can be used for street fun but for a serious drag truck, you will need to keep an eye on it since as described once it goes bad, they have a tendency to come apart. For full on drag cars I wouldn’t considering one. In reality all diffs have a life expectancy, just like oil, shocks, springs, u-joints, etc. Most people drive it till it breaks down or fails.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-13-2006, 03:39 PM   #10
SSC's76
No No
SSC's76's Avatar
Well then I'll chime in here. I had 2 gov lock setups in my camaro. I grenaded the first one 3 weeks after I got the car. I did not "abuse" it I came to a stop sign that had some loose gravel, got on the gas enough to break the tires loose got some clean pavment let off the gas and blaaclunk. The car screached to a halt. The second grenade lock let go at the track with a measly 165hp L69 putting the umph out.
The problem is when you do get traction with a gov lock the pins in the picture above break out of the carrier and boom.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-13-2006, 05:28 PM   #11
84 400
Sb 400 club
84 400's Avatar
i had a gove lock in it and it worked great with the 305 i had no wheel spin ever. in the snow it was a blast doing doughnuts in the parking lots. the only time it gave me trouble was when i was cornering slow and i could here it clunking. after changing the gear oil it was fine. i wish i had swapped it inot my 84 so i could get a two tire fire. this was not posi really it had an "I" shape bar in it and it coked up not like a limited slip.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-13-2006, 09:25 PM   #12
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I had a 4x2 with a 12-bolt Gov-lock. I drove it easy, but one tooth on the "Swiss watch" locking mechanism broke off when I was 100miles from home. Made it home under its own power, but chewed things up until the cover magnet caught the tooth. Even in a pickup treated nicely a 12-bolt Gov-lock WILL break--the question is just WHEN. A 10-bolt Gov-lock's performance will be similar. If they are free use them until they break, but don't spend money on them.
I have heard the 14-bolt Gov-locks are better, but I don't have any experience.
I like the idea behind the Gov-lock, but I replaced it with an Eaton which I'm very happy with.
badpeanut is offline   Reply With Quote
Old 12-13-2006, 10:05 PM   #13
edman87
junk collector
a gov lock is OK at best and that is on a truck that sees nothing worse than a gravel road with stock size and traction tires in a 4wd truck. In a 2wd street truck, it is Ok for a stock truck driven easily. As said before, when it goes, it wipes out everything else too.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 12-14-2006, 11:22 AM   #14
Zoomad75
K5Camper
Zoomad75's Avatar
They are called gov bombs for a reason. Kaos has a point that if treated gently they won't break. The problem is when one of us power hungry addicts starts hammering on one. It's only a matter of time before it blows up. The silly thing is they can grenade due to extreme punishment or just turning the corner in the rain, slipping and then catching traction under light throttle. For it to break in such light use might be due to previous beatings and finally letting go. From what I've seen, once you hear something snap, its too late. They rarely give any warning to thier impending doom.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-21-2006, 01:13 AM   #15
jimfulco
jimfulco is offline   Reply With Quote
Old 12-21-2006, 01:36 AM   #16
crazy longhorn
Fabricate till you "puke"
2 words......TRASH CAN! the last pic should tell the story CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
