Old 12-13-2006, 02:42 AM   #1
masterbeavis
Having issues
masterbeavis's Avatar
Will eaton 5.14 gears work in a 4.10 carrier?
I have a set of 5.13's that are in a thrid that does not have the ring gear preload bolt. I'd like to know if the gears will swap over and work in a 4.10 third that has it? I'd like to upgrade simply to take advantage of the feature to keep my ring gear from deflecting under power. Common sense dictates that they all should interchange with no problem, but there is carrier breaks on other axles....
Ive never had em apart, never tried taking it apart... Do these things take shims, have adjusters, what?
masterbeavis is offline   Reply With Quote
Old 12-13-2006, 11:08 AM   #2
gouldie
Re: Will eaton 5.14 gears work in a 4.10 carrier?
they should fit if they are the same type of center section.
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
Old 12-13-2006, 01:01 PM   #3
wolfthing2000
They set up easy. Just get an old motors truck manual and you should have all the info in there.
wolfthing2000 is offline   Reply With Quote
