Old 12-13-2006, 04:14 PM   #1
shane72_383
shane72_383's Avatar
Header Leaks
What are everyone's tricks for making headers stop leaking? i just replaced the header gaskets on my truck and they are already leaking again. Also what is a good set of headers that don't warp and dont leak? is there such a thing?
shane72_383 is offline   Reply With Quote
Old 12-13-2006, 04:26 PM   #2
jkaylor68gmc
jkaylor68gmc's Avatar
Re: Header Leaks
Try installing a set of the Mr. Gasket Copper units from Advance. Install the embossed ring side into the head and the flat side on the header. When you tighten the bolts work from the two center bolts outward. No matter what headers you have and how cheap, this will usually work.
jkaylor68gmc is offline   Reply With Quote
Old 12-13-2006, 04:30 PM   #3
Jim_PA
Re: Header Leaks
I prefer Fel-Pro header gaskets. I've never had a problem with them leaking.
Jim_PA is offline   Reply With Quote
Old 12-13-2006, 04:58 PM   #4
49studebaker
49studebaker's Avatar
Re: Header Leaks
My first question would be...what headers are you using? I've had headers that have leaked and after installing different brands of gaskets, (not what is mentioned above, this was 20 years ago), put them on double, they still leaked. Is it just one side? That's been my problem. My opinion is some headers either get warped or were not quality made in the first place. I put Hooker Comps on my 85 4x4, ten years ago, the headers look like crap but I've never had a leak. I look for the thicker flanges and quality brands. I am currently getting a small exhaust leak on the Hooked Block Huggers on the H.O. 350 in my Studebaker but it seems that it is due to getting the header bolts to stay tight against the ceramic flanges.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 12-13-2006, 05:06 PM   #5
bryanw1968
bryanw1968's Avatar
Re: Header Leaks
Couple of things.....
Hooker and Heddman both make good thick flange hedders that don't leak.
I happen to prefer the Heddman Elites as not only do they have a 3/8" flange, they also have ball joint fittings on the collector that NEVER leak and don't require a gasket.
Another general gasket trick is to soak the gasket in water for a couple of hours and let them swell. Put em' on what and tighten from the center out(like mentioned above).
I've seen really expensive copper gaskets that are supposed to work well but I've never tried them.
Good luck!
B-dub
bryanw1968 is offline   Reply With Quote
Old 12-13-2006, 06:31 PM   #6
Imacarguytoo
Re: Header Leaks
All i buy are cheap black jack headers. When i install them i take a sander and sand off the paint on the flange that goes to the head. I also throw the header gaskets away, and go buy some exhaust manifold gaskets. Sometimes i have to snip the ends so i can just drop the gasket in after i install the bolts. Liek someone else said tighten the inside bolts to the outer bolts so it seals up good.
I never get header leaks this way. Also on headers that have been on a vehicle i just bought i change the old leaking gaskets and sometimes have to run 2 sets of manny gaskets to get a good seal. Hope this works for you. Also manny gaskets are like under 5 bucks. Cheaper than header gaskets.
Imacarguytoo is offline   Reply With Quote
Old 12-13-2006, 07:14 PM   #7
zeeklu
Re: Header Leaks
http://store.summitracing.com/partde...5&autoview=sku These bolts can't come loose and work great. I've used them for years and never had a leak. Chris
zeeklu is offline   Reply With Quote
Old 12-13-2006, 07:23 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Header Leaks
I have the "Elites" on "GQ"
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-13-2006, 07:31 PM   #9
49studebaker
Re: Header Leaks
LUV, how do the Elites fit, I assume 350 ci.?
Old 12-13-2006, 07:40 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Header Leaks
Pic's in my siggy link, they are 3/4 length, not full length, I had to
remove the spark plugs to instal them, that's it, I luv them alot
Old 12-13-2006, 08:15 PM   #11
centsless
sufficiently talented fool
centsless's Avatar
Re: Header Leaks
I bought a set of Flow-Tech headers from summit. I currently have them installed without any gasket at allat the engine. They do not leak a bit. They have also not come loose. I have put 450 miles on the truck so far, and they are fine!!!! I have always had trouble with header gaskets, and can't believe these work like this. Especially since I bought the cheapest set I could find.....
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-13-2006, 08:24 PM   #12
whatnow123
whatnow123's Avatar
Re: Header Leaks
What I did was I just welded my directly to the head, saves money on gasket buyin and mine don't leak at all no more.
Just kidding. But i do have a question about "installed without any gasket at all" Is this okay to do? Doesn't seem like this is a good idea.
Mine leak from the middle drivers side, it's driving me nuts.
whatnow123 is offline   Reply With Quote
Old 12-13-2006, 08:26 PM   #13
Slammed70
Slammed70's Avatar
Re: Header Leaks
Ive always ran headers on any vehicle I owned(But I recommend manifolds on V8 S-10s) and they have always leaked. No matter what I did. But recently I have remidied this problem on my Camaro. 3/8 flange, the cheap parts store 1inch header bolts, 30 cents worth of lock washers, and the cheap ****ty paper header gaskets. Not a leak in over a year.
My truck on the other hand.....Hi-temp (red) RTV around the ports. And thats it, no leaks either.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-13-2006, 10:00 PM   #14
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Header Leaks
A SLICK TRICK for your header bolts: Clean the bolts and wrap them with "Teflon Tape", just like you would a pipe fitting. The tape keeps the header bolts from backing out and helps to keep the threads clean for the next time you pull them on purpose. I read about it in one of the inventive ideas area of Sporttruck magazine and have been doing it to my bolts since 1996. Try it and you will be surprised at the fact they do not back out.
Old 12-13-2006, 11:07 PM   #15
sick69
sick69's Avatar
Re: Header Leaks
another trick with small block headers it to use felpro exhaust MANFOLD gaskets instead of header gaskets. been using this trick for years and always seems to work great unless the headers are just plain junk. haven't had an exhaust leak at the head since ive started usng them
I haven't tried it on a big block yet so i dunno if it will work with them or not
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-13-2006, 11:22 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Header Leaks
which end of the header is leaking? The top, or tha collectors?
Old 12-13-2006, 11:36 PM   #17
bowtiehotrodder
SIX BANGER
bowtiehotrodder's Avatar
Re: Header Leaks
the best header gasket is the soft aluminum ones and they dont leak. they are 30.00 to 40.00 dollars
http://www.cardomain.com/ride/2597018(NN)
1979 chevy truck swb 454 w turbo400 with buckets
1977 chevy truck swb soon to be 454
1976 chevy dually 454
1969 chevy truck six shooter
bowtiehotrodder is offline   Reply With Quote
Old 12-14-2006, 12:25 AM   #18
ZOOMY
Re: Header Leaks
Cut the connecting metal out between the flanges. Bolt them in TIGHT with grade 5 and then stake the heads of the bolts.
ZOOMY is offline   Reply With Quote
Old 12-14-2006, 12:42 AM   #19
HuggerCST
HuggerCST's Avatar
Re: Header Leaks
I've also had good luck with red high temp silicone with no gasket. (at the head)
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 12-14-2006, 01:08 AM   #20
shane72_383
Re: Header Leaks
Thanks for all the replies, im gonna try some of these i'll let ya know how they work.
Old 12-14-2006, 01:31 AM   #21
72armyswbtruck
72armyswbtruck's Avatar
Re: Header Leaks
I use the metal header gaskets, they seem to work well
JM2C
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-14-2006, 02:28 AM   #22
Slammed70
Slammed70's Avatar
Re: Header Leaks
Are you talking about those "dead soft" type? Those are junk....I blew three or four sets of those out in my Camaro.
Old 12-14-2006, 08:41 AM   #23
68C15
blood type; Retumbo
68C15's Avatar
Re: Header Leaks
I put a set of copper gaskets behind my used heddmans with standard 12 point headed bolts 3 years ago and havent touched them since. about $30 all together, done!!!!
68C15 is offline   Reply With Quote
Old 12-14-2006, 08:43 AM   #24
Jim_PA
Re: Header Leaks
Here's my second vote for FEL PRO -- 14 or 15 bucks, no leaks, no blowouts, and they don't cost 40.00
Old 12-14-2006, 01:28 PM   #25
Mudder
Mudder's Avatar
Re: Header Leaks
Been down the road and have it firgured out. $5 for manifold gaskets and cut the flanges on boht sides of the center tubes. Like Zoomy said. Takes the warpage out of the flange which makes the bolts come loose. No need to buy expensive bolts and or gaskets. Mine are cut.
Mudder is offline   Reply With Quote
