Old 12-13-2006, 07:51 PM   #1
ScottH
ScottH's Avatar
Need suggestions on maintenance for 79 K10
Just bought a 79 K10 with 350/350/NP203 combo with 92K on it. PO wasn't the hands on mechanical type so pretty much just did what was needed. This is my first 4x4 truck and could use some suggestions/recommendations on what type of maintenance (other than the obvious) you guys would suggest. I'm wondering if the full-time hubs, or transfer case, axles, etc. should need any attention.
Any help is appreciated. Happy holidays to all.
Thanks.
Scott
ScottH is offline   Reply With Quote
Old 12-13-2006, 07:59 PM   #2
1969k10stepside
Re: Need suggestions on maintenance for 79 K10
I would check the fluids in the differentials,the transfer case,tranny,ect and fill as needed.Grease all the zerks you can find if they need some grease,check for worn out u joints.
1969k10stepside is offline   Reply With Quote
Old 12-13-2006, 08:03 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
If you are unsure of what's been done or where it's been it would be a smart thing to at least change ALL the fluids. Or at least everything but the trans as High mileage autos have a wierd tendancy to die after fluid changes if they were poorly maintained before. (not sure why)
Changing the fluid in the axles will give you an idea of the condition of the gears and how good or bad the truck was treated. Doing the t/case will add peace of mind that it's fresh. I'd take hubs apart and check the wheel bearings and repack them.
My truck looked to be well maintained, but when we pulled the hubs apart the first time they were due for replacement.
Overall, it gives you an opportunity to look everything over and start fresh.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-13-2006, 10:17 PM   #4
ScottH
ScottH's Avatar
Thanks for the suggestions. Can you give me an idea of what is involved with some of these? Obviously the axles I'm assuming are like most others, pull the cover, replace gasket, and fill. What about the transfer case? Also what is involved with the full-time hubs?
Sorry for all the questions, everyone's help is appreciated. Gonna have to dig out some of my manuals to see if they cover 4x4s.
Old 12-14-2006, 04:35 AM   #5
Mudder
Mudder's Avatar
I use regular 10W30 or 40 motor oil for the transfer case. One thing I would consider is changing to lockouts and changing the transfer case over to part time. There is info here on doing this.
Mudder is offline   Reply With Quote
Old 12-14-2006, 01:54 PM   #6
blink32
blink32's Avatar
The 203's don't take a heavier weight gear oil like 80w90, etc in the 205?
blink32 is offline   Reply With Quote
Old 12-14-2006, 02:07 PM   #7
Mudder
Mudder's Avatar
Nope some may disagree but I was told many years ago to use 10W40 and thats all I have ever used. I have had really good luck with the 203.
The 203 is chain driven and the 205 is a gear driven.
Old 12-14-2006, 05:36 PM   #8
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 12-15-2006, 01:34 AM   #9
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I use to use ATF in my old 203...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-15-2006, 07:47 AM   #10
blink32
blink32's Avatar
All very interesting. I never had a reason to research the 203 but this is all good to know.
Old 12-15-2006, 10:34 AM   #11
ScottH
ScottH's Avatar
My Chilton and Haynes manuals both say to use 10W-40 motor oil in the NP203.
Old 12-18-2006, 01:09 PM   #12
ScottH
ScottH's Avatar
Can anyone tell me what is involved in the full-time hub maintenance?
Does the cover just pull off and you service it similar to any front wheel bearing?
Thanks guys.
Old 12-18-2006, 01:22 PM   #13
us111
hello,,i too have a k-10 and wasnt going to pull the front hubs but thankfully one of the lockouts started acting up,,glad it did,,pulled it apart and it was a mess in there,,old nasty watered down grease,rust etc..so you definitely wanna check that kinda stuff..also everyone i've talked to on here and other 4 wheeler's have all suggested 10-30 or so for t-case,,been told it is easier to get it spashed up on the chain than a grease.....
us111 is offline   Reply With Quote
Old 12-20-2006, 12:41 PM   #14
ScottH
ScottH's Avatar
So what is involved with servicing the front hubs?
Thanks.
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
Old 12-20-2006, 01:58 PM   #15
Mudder
Mudder's Avatar
Taking them apart which can be a pita without a diagram and cleaning, regreasing it all. The snap rings can be a pita. Not a big deal after yu have done them a couple of times.
Old 12-20-2006, 02:06 PM   #16
blink32
blink32's Avatar
Start googling. These links are for Dana44 manual hubs but you get the idea:
http://www.pavementsucks.com/tech/dana44hub.php
http://www.keystonekrawlers.com/Mods...ub_rebuild.htm
Old 12-21-2006, 10:37 AM   #17
ScottH
ScottH's Avatar
Thanks to all......and happy holidays!
Old 12-21-2006, 07:40 PM   #18
us111
i've never worked on full time hubs myself but sure these guys know...
