Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 12-15-2006, 06:40 PM   #1
rage'nrat638
rage'nrat638's Avatar
sbc / bbc valve train adjustment
The adjustment is 1/2 turn down from zero lash. (GM MANUAL SAY'S 1 TURN)
In order for the hydraulic lifter to work correctly, it must be centered.
If your valves have come out of adjustment after several thousand miles of
operation, suspect your rocker arm nuts, and replace them. They do wear out
after constant adjustments.
When adjusting your valves, tighten all adjusting nuts until all lash is
removed by feeling the rotation and up and down movement of the pushrod. Next, set your engine on
TDC #1, pointer at "0". You can now adjust the following valves:
INTAKE on cylinders 1,2,5,7
EXHAUST on cylinders 1,3,4,8
Loosen the adjusting nut until lash is felt by rotating the pushrod. Then
tighten the adjusting nut while rotating the pushrod until all lash is
removed. Now tighten the adjusting nut 1/2 full turn. This "centers" your
lifter.
After you have adjusted the above valves, rotate you engine 360 degrees
bringing the pointer around to the 0 TDC mark. This is TDC #6. Adjust the
following valves in the same manner:
INTAKE on cylinders 3,4,6,8
EXHAUST on cylinders 2,5,6,7
Your valves are now adjusted properly.
good luck and may the force be with you
as per the g.m manual..
rage'nrat638 is offline
Old 12-18-2006, 10:58 AM   #2
woodridge
woodridge's Avatar
Re: sbc / bbc valve train adjustment
I have used this for years and is the best way. Thanks for posting this, I always have to go to the book.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline
Old 12-18-2006, 11:24 AM   #3
Billla
Billla's Avatar
Originally Posted by rage'nrat638 View Post
The adjustment is 1 turn down from zero lash.
As noted previously, this is not true for all cams.
Billla is offline
Old 12-27-2006, 04:12 PM   #4
corn
High RPM engines usually run between 1/8-1/2 turn. I generally run 1/2 turn on everything...
corn is offline
Old 01-03-2007, 05:49 PM   #5
65-72 chevytoys
65-72 chevytoys's Avatar
WHen you say zero lash which is the same as remove all lash. THat is when you can feel the push rod rotate underneath the rocker and tighten the nut until the push rod just stops the rotation correct?
65-72 chevytoys is offline
Old 01-03-2007, 06:11 PM   #6
Billla
Billla's Avatar
Zero lash is when there is no vertical movement of the pushrod, typically when you just start to feel drag when rotating the pushrod. Tightening until you can't turn the pushrod is far too tight!
Billla is offline
Old 01-28-2007, 09:38 PM   #7
65-72 chevytoys
Ok assuming I have the right TDC on the compression stroke. I tightend each rocker nut until I felt drag on the pushrod then tightend another half a turn. I am thinking this is what mark is talking about. However Billa once I tightend the extra half turn I could not turn the pushrod anymore. Should I loosen it up again so the pushrod turns? Then when I rotated the engine 360 to finish the rest of the valves the pushrods on #1 cylinder can turn again. Now I am confused?
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
Old 01-28-2007, 09:49 PM   #8
Billla
Billla's Avatar
You're doing everything right You shouldn't be able to turn the pushrod once you've established the preload with the 1/2 turn.
What you're doing here is pushing against the spring inside the hydraulic lifter.
Billla is offline
Old 01-28-2007, 10:23 PM   #9
65-72 chevytoys
Thanks that cleared up the confusion. Now I have to make sure I had the right TDC. I think I did because both the intake and exhaust valves were closed. If I had been 180 out the exhaust would have been open correct? and should I go past 1/2 turn to 1 full turn?
Old 01-28-2007, 10:37 PM   #10
Billla
Billla's Avatar
Correct; if both valves were closed (on the base circle) then you are on TDC compression...right where you need to be.
Billla is offline
Old 01-28-2007, 11:15 PM   #11
65-72 chevytoys
Thanks Billa you have been a big help. I have the valves adjusted and right. Now all I need to do is start the engine and see if that fixed my lifter noise.
Old 01-28-2007, 11:19 PM   #12
Billla
Billla's Avatar
We'll be rooting for you - let us know how it goes!
Billla is offline
Old 01-30-2007, 11:31 AM   #13
prostreet1967
prostreet1967's Avatar
im guessing since the firing order is the same for a small block and big block u adjust the same valves on number 1 and 6
prostreet1967 is offline
