Old 12-16-2006, 10:35 AM   #1
76bonanza
76bonanza's Avatar
need quick help with oring water neck
When installing new thermostat do I use any rtv on the termostat? I know none on the o-ring but I removed some from underside of thermo just wondering if this is nessary with the o-ring or all dry?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-16-2006, 11:48 AM   #2
ratrod67
ratrod67's Avatar
Re: need quick help with oring water neck
No sealant is needed.
ratrod67 is offline   Reply With Quote
Old 12-16-2006, 01:02 PM   #3
QKENUF4U
QKENUF4U's Avatar
but good luck with it actually sealing for very long. i bought a stock neck for like 12$ after my o-ring one leaked after about a week.
QKENUF4U is offline   Reply With Quote
Old 12-16-2006, 01:14 PM   #4
kwmech
I had the same thing happen, then I put silicone to seal it, then it corroded. What a piece of s...
Old 12-16-2006, 01:16 PM   #5
Bob D
Rolled on Paint Club
Bob D's Avatar
Put sealant on the bolts. Some of the threaded holes for the bolts are drilled into the water jacket on the intake. I found this out the hard way
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 12-16-2006, 03:40 PM   #6
76bonanza
76bonanza's Avatar
I have heard the orings suck, and the orings are the best ever. So I decide to try the orings first and go from there did not get a chrome coated one just polished billet
1968 c10
lowered 3" 4"
Old 12-16-2006, 04:30 PM   #7
corn
Use a gasket with it. It helped mine so far...
corn is offline   Reply With Quote
Old 12-16-2006, 04:59 PM   #8
76bonanza
76bonanza's Avatar
So far it is working fine. We will see.
1968 c10
lowered 3" 4"
Old 12-16-2006, 05:53 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
I have had no issue with the higher dollar O-ring necks, like the ones that Billet Specialties makes. The cheaper ones are a gamble either way, and if they leak then they are of cheap enough metal that they start a corrosive action at the mounting surface and then the intake gets pitted. Go for quality and be happy with the results.
