Old 12-17-2006, 01:14 AM   #1
skokie
skokie's Avatar
A arm removal and rebuild
I tried doing a search for this but came up empty. How do you remove the a arms and all that is attached to it and then rebuild it? I know that is pretty vague but then so is my knowledge of suspensions
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-17-2006, 01:19 AM   #2
poorboy
poorboy's Avatar
Re: A arm removal and rebuild
The uppers should screw in and out and the lowers are pressed. You shoud buy a Chilton's manual for the truck. They are nice to have around.
poorboy is offline   Reply With Quote
Old 12-17-2006, 01:24 AM   #3
skokie
skokie's Avatar
I have one somewhere. Matter of fact Im going to go look for it now BRB
68 build thread
Old 12-17-2006, 01:27 AM   #4
skokie
skokie's Avatar
I found it. Ok time for some reading.
68 build thread
Old 12-17-2006, 02:10 AM   #5
nandress
nandress's Avatar
The lowers are also screw in and out. Just a bit bigger nut!! And Gorrilla torque!!
Save yourself the trouble...if you find that the arms have mucked up threads (they are subtle, but you should be able to tell) find a new set of arms. Also, get yourself new cross shafts and bushings, the Moog ones are supposedly the best quality, and I liked the ones we got. In any case, if the bushing nuts do not thread in easily, you will just have trouble. Get new arms.
nandress is offline   Reply With Quote
Old 12-17-2006, 02:12 AM   #6
skokie
skokie's Avatar
Can you remove the entire arm with everything intact or do you have to take some stuff off?
68 build thread
Old 12-17-2006, 02:28 AM   #7
nandress
nandress's Avatar
You should probably pop the spindles to relieve the springs (very carefully, and much easier to do if your truck front heavy, i.e., with engine, using a floor jack to slowly lower the lower arm and also compress it when you are ready to put it back together). If that is what you are asking.
I think it is easiest to take the arms off and then pull the shafts, but you may have to do the final tightening of the shaft bushings with the arms installed back on the truck...it provides a better grip and leverage!!
Old 12-17-2006, 02:28 AM   #8
poorboy
poorboy's Avatar
You can remove the upper or lower by themselves. Ifd you take the upper off support the lower. If you take the lower off lower it with the floor jack once it's doisconnected from the spindel and the shock is removed. This way the spring will not shoot out.
Old 12-17-2006, 02:30 AM   #9
poorboy
poorboy's Avatar
Does your truck have disc's? If not now is a prime time for a conversion.
Old 12-17-2006, 02:38 AM   #10
jimmydean
jimmydean's Avatar
When I looked at how much it was to rebuild my upper arms, I decided I was going to just replace them with tubular upper arms. My lowers are ok now that I replaced the ball joints when I put the drop spindle discs on.
jimmydean is offline   Reply With Quote
Old 12-17-2006, 08:49 AM   #11
70GMCer
70GMCer's Avatar
This should help.....
steve
http://67-72chevytrucks.com/vboard/s...ad.php?t=13696
http://67-72chevytrucks.com/vboard/s...ad.php?t=20551
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-17-2006, 02:08 PM   #12
skokie
skokie's Avatar
Poorboy that is a part of this as well if I have the $$ for it 70gmcer I will check out those threads.
68 build thread
