Old 12-18-2006, 01:21 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
Front drive shaft I.D.
My K5 didn't have a front drive shaft when I purchased it. The PO said that this drive shaft went with the truck, but after I looked under and saw the yoke, I new better. Of course I took it with me anyway. Here's my question. What application is this shaft for. Compressed like it is in the picture it is about 33 inches long, and the u-joints seem to be the same as the ones on the back shaft. Could I take the flange off and use the CV with my yoke?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-18-2006, 07:55 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Front drive shaft I.D.
That is a later model shaft that uses the Saginaw double cardan instead of the Spicer that was used in the earlier trucks. There is a flange available for the front output of your 205 that would allow you to use that shaft. You can find the flange on mid/late '70s trucks with a 205 (mostly manuals). The Saginaw and Spicer parts will not mix and match. The front axle joint is a Spicer 1310 on all GM solid front axles.
Also, the length of the shaft may or may not be correct depending on original application.
Blazer1970 is offline   Reply With Quote
Old 12-19-2006, 06:19 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
So this shaft is off of a later model, say a 73 to 80? Which is stronger? Should I get a driveshaft to match my yoke on the NP205, or should I get a flange so I can use this shaft?
Old 12-20-2006, 07:43 AM   #4
Blazer1970
Blazer1970's Avatar
I don't think there is any appreciable strength difference. If the u-joints and slip joint in that shaft are in good condition, you could probably find a yoke for the t-case pretty easily. Look closely at the slip joint as they tend to wear fast on front shafts and that one does not look even close to new. A driveshaft shop could swap out the CV on that shaft to a Spicer also. It all depends on what is good on that shaft and what the cost of the repairs/parts will be as to what is cheapest to do.
