Old 12-20-2006, 07:18 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Has anyone....?????
Has Anyone converted over from a th350 to a th400 in there K5 or Jimmy?
Angelse68cal is offline   Reply With Quote
Old 12-21-2006, 02:01 PM   #2
pharcyde05
pharcyde05's Avatar
Re: Has anyone....?????
I changed mine out
pharcyde05 is offline   Reply With Quote
Old 12-21-2006, 02:01 PM   #3
gmcman7202
Active Member
gmcman7202's Avatar
not that a big a deal to do.
gmcman7202 is offline   Reply With Quote
Old 12-21-2006, 02:02 PM   #4
hotrodhomi
hotrodhomi's Avatar
mine has a th400
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 12-21-2006, 03:18 PM   #5
Angelse68cal
Cochino_Racing_909
I am talking about changing it in a 4X4! Oh yea and wht is Axel Wrap?
Old 12-21-2006, 05:08 PM   #6
gmcman7202
Active Member
gmcman7202's Avatar
still isnt a big deal, i am not sure what t case adapters you might need, or if the splines match, since i dont know the specs of the 2 off hand, as gm made the needed adapters, as the t case used is gona be diffrent for diffrent years, ect...
Old 12-23-2006, 06:29 PM   #7
JimKshortstep4x4
We don't have a TH 400 in a Blazer but we have one in a short box 4x4. Since the TH 400 is longer there are some mods to be made in addition to the transfer case adapter, (the NP 205 is the same for both tranny's). The longer TH 400 requires a longer front drive shaft, a shorter rear drive shaft and the crossmember needs to go rearward. The side mount for the transfer case has to be relocated. The transfer case shifter has to be bent in an "S" shape to move it forward. The shift linkage is different, also.
Jim
Old 12-24-2006, 09:12 AM   #8
jaros44sr
jaros44sr's Avatar
Hey Jim, thanks for the heads up and info. Just picked up my TH400 and was not sure what was involved, sounds pretty strait forward, I have a floor shift so no problem there, but how do you bend the transfer case shifter. Just heat and bend around a suitable mandrel?
Merry Christmas, J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-24-2006, 10:46 AM   #9
MNorby
MNorby's Avatar
another thing the th400 will have a 32 spline output whereas the th350 has a 27 spline output so you'll either have to change the input gear into the case or swap t-cases
MNorby is offline   Reply With Quote
Old 12-24-2006, 10:51 AM   #10
JimKshortstep4x4
We just heated and bent the shift lever. It was a lot of bending and the shift lever is pretty short by the time you get it into the right position.
We use the truck for towing a car trailer and the TH 400 works great!
Jim
Old 12-24-2006, 11:28 AM   #11
jaros44sr
jaros44sr's Avatar
Does anyone make an adapter 32-27 spline? Isn't there a coupling between the trans and transfer cs.
SAFETY FIRST
AS usual, off topic
Jim
Old 12-24-2006, 12:13 PM   #12
MNorby
MNorby's Avatar
If your going to run a TH400 to a NP205 its just the input gear into the t-case. on a 205 if you are going from 27 to 32 you will need the 32 gear and to have a machine shop bore out the bearing hole. I had that done to convert my 10 spline 205 to 32 spline for my doubler. NWF sells input gears http://northwestfab.com/ Also you'll need the adpater from the tranny to case and that adapter can be $$$ since was a rare fatory option. I believe NWF mills them too and you can sometimes fond them on ebay for around $150 or so. You could go with a th400 into a NP208 or 241 alot easier/ cheaper too since that was a very common setup. I have a 241 sitting here just collecting dust.
Old 12-24-2006, 10:07 PM   #13
JimKshortstep4x4
You may want to check this place out. They have an input shaft for the TH 400 to the NP 205. I am not sure if their part has any complications so you would want to talk to someone.
Here is the link: http://www.drivetrain.com/
Click on Transfer Case parts. The part number is ALT 13929 and lists for $104.
Jim
Old 12-25-2006, 04:45 PM   #14
jaros44sr
jaros44sr's Avatar
Jim
Thanks that might work. I see a heavy duty listed as well. I'll go with the bigger bearing and bore out the case at the same time. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 12-27-2006, 01:48 PM   #15
Angelse68cal
Cochino_Racing_909
Advance adapters in northern California Has everything you need to make the conversion. Also I dont have a bench seat so I Dont have to Bend the t case Shifter. Really I noticed it moved it back like 3 inches. So I am going to have to Weld up the old Hole on the trans cover and cut a new one.
www.advanceadapters.com
Old 12-28-2006, 07:49 AM   #16
vtblazer
vtblazer's Avatar
Why do you want/need a th-400 when a properly built th-350 could work just as well?
Shift points are different, first gear is higher and they rob more power from the drive train.
Flame suit on
vtblazer is offline   Reply With Quote
