Old 12-21-2006, 01:23 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
an easy negative battery disconnect
After reading about someones truck catching fire and then another spoke about that our trucks can catch fire even while its turned off, it got me wondering and worried about my truck catching fire while in the garage while i'm sleeping...
I think its time to have a battery disconnect.
who has one and what does it look like exactly. Pictures would be very helpful. Do i have to pop the hood everytime and unscrew a knob or is there one that can operate inside the cab?
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 12-21-2006, 01:27 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Re: an easy negative battery disconnect
Ive got one on my truck, its the blade handle type. will get a pic up later.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-21-2006, 01:53 PM   #3
ClassicRedneck05
ClassicRedneck05's Avatar
there is ont in Jegs where the Switch is under the hood but has a lefter u can run inside the cab to kill it
ClassicRedneck05 is offline   Reply With Quote
Old 12-21-2006, 02:43 PM   #4
pat
pat's Avatar
Im putting this one on the positive cable going from my battery under the bed to the starter. It is going to stick through the floor of my cab under the seat.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 12-21-2006, 02:48 PM   #5
Boise69
The Hammer Man
Boise69's Avatar
very cool. i will look into this. I just wonder if that red plastic handle will withstand the constant switching ?
1997 MBZ E420
Old 12-21-2006, 03:45 PM   #6
grebus1
grebus1's Avatar
Here is the one that I'm considering (side terminal), just not sure if it will fit OK. My goal is to find one that is easily adapted to my current setup with a side terminal battery.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 12-21-2006, 11:21 PM   #7
Boog
laying low
Boog's Avatar
I don't know about these mounted on the batteries. It looks like just that many more places for corrosion to attack and cause starting/charging problems. For now while mine is under construction I just remove the positive cable when I leave it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-21-2006, 11:57 PM   #8
krue
Designated A-hole!
krue's Avatar
Keeps the battery from draining while it sits.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-22-2006, 12:02 AM   #9
FarmTruk
In Memoriam...
FarmTruk's Avatar
I have used this type on tractors before with good results.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 12-22-2006, 12:09 AM   #10
bad_turbo
turbo enthusiast
bad_turbo's Avatar
use this one on alot of race cars. Mount them on the back by the trunk and taillights. Hide it in the cab and it doubles as a theft-deterrent.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 12-22-2006, 01:02 AM   #11
corn
I used one like this on my old chevelle. Sure makes sleeping easier, problem wise & theft wise. Disconnecting the battery works fine too...
corn is offline   Reply With Quote
Old 12-31-2006, 12:07 AM   #12
project1971
project1971's Avatar
They also use those style switchs on ambulances for all the load of radios and lights.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 12-31-2006, 12:12 AM   #13
68C15
blood type; Retumbo
68C15's Avatar
what about the solenoid type that motorhomes use? it uses a remote switch. (ie. auxillary power)
68C15 is offline   Reply With Quote
Old 12-31-2006, 12:15 AM   #14
corn
That would just kill the start position wouldnt it?
Old 12-31-2006, 02:43 AM   #15
pritch
pritch's Avatar
You can hook up a simple soleniod real easy. I always do this on demo derby cars. I have a diagram around here somewhere, but it kinda goes like this:
Hook up your positive or negitive cable from the battery to the big post on the soleniod, then to ground or starter, whichever wire your on. I always use the positive side. Then control the solenoid with a small toggle switch. On the demo cars, this switch is obvious and handy, but it would be easy to hide somewhere. One drawback-you need to run a wire directly from the battery to the solenoid to power the solenoid. If you feed the solenoid from the fusebox or somewhere, as soon as you activate it to kill your main power, it kills the power to keep the solenoid open.
I guess someone will know if this would be too much of a battery draw to use for a long time, but it should work good for short trips into bad neighborhoods.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
