Old 12-22-2006, 11:46 AM   #1
pkj
want to trade
i will trade a complete PPG paint kit that will include at the very least jp202- 2 part primer,200? sealer, base coat, dcu 2021 clear, wax & degreaser, strainers, mixing cups, mixing sticks,tac rags, final wipe towels, all reducers and additives. any color or cmbination of colors. this will be a generous kit in volumn. you wont run out unless you dump it on the floor. i can supply differnt stuff if needed aslong as its PPG i will send a final spray-out card on choosen color first. stuff i am looking for:
air managment kit-i already have bags and brackets mounted, need rest
drop spindal, 6 lug disk brake front conversion kit
sb scatter shield, 400 sb flywheel, good clutch set-up
good performance heads for 400 sb, read my 400 opinions needed thread under engine section.
dual quad set-up
aftermarket hei
good oilpan
roller rockers
i dont know so what do yiu have you want to trade, like i said i can make the paint kit as complete as you want to go any level you want to take you truck to. please respond by this post first.
pkj is offline   Reply With Quote
Old 12-22-2006, 12:43 PM   #2
72dually
72dually's Avatar
Re: want to trade
Wow.......I wish you were closer But I think shipping would be excess
I could get the front disc brake set-up w/stock spindles or without, including the rear camaro/impala disc brakes brake setup too
Pan
Roller rockers
70 GMC shortbed fleetside with a 72 chevy costume
72dually is offline   Reply With Quote
Old 12-23-2006, 09:42 AM   #3
pkj
Re: want to trade
ttt
Old 12-24-2006, 01:03 PM   #4
pkj
Re: want to trade
thanks for all the responses pm to me. anyone else intreasted? pkj
Old 12-24-2006, 06:47 PM   #5
454_72_4X4
454_72_4X4's Avatar
Re: want to trade
I've got a 7 quart oil pan, (gotta find the pump pickup...), and maybe a good clutch setup.
I also have a balance plate that allows you to use any "normal" chevy flywheel, (internally balanced).
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-25-2006, 01:20 PM   #6
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
Re: want to trade
i have a standard shift small block 400 flywheel and a set of 461 double hump heads if your interested.
BIGCHEVYMAN is offline   Reply With Quote
Old 12-30-2006, 12:13 PM   #7
pkj
Re: want to trade
ttt
