Old 12-28-2006, 02:47 AM   #1
abadsvt
abadsvt's Avatar
Will this be okay?
Well i finally got my brakes in from CPP. They came fast and without any backorders that CPP is famous for . The problem. I took my rotors down to a local machine shop to have them redrilled to 5x4.75 bolt pattern. There are a few support ribs on the back of the rotor that are in the way to have them redrilled. I was wondering if it would be bad to grind them down so i can change my bolt pattern? I really don't want to use wheel adapters so redrillen the bolt pattern is my goal. Thanks and any comments ASAP would be appreciated. Thanks Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-28-2006, 11:33 AM   #2
jimmydean
jimmydean's Avatar
Re: Will this be okay?
I would ask a brake shop to be sure, but depending on how you are closing up the old holes might make a difference.
jimmydean is offline   Reply With Quote
Old 12-28-2006, 03:51 PM   #3
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Many many years ago I had a set of 6 lug hub/rotors off my pro-street Chevy Luv redrilled to 5 lug. The machine shop left in the 6 lug hub-to-rotor mounting bolts and cut them off flush. when the 5 lug pattern was drilled in, 2 of the new bolt holes were touching the old holes, but the old bolts acted as filler and everyting worked great. Still together 12 years later. What Im getting at is this: maybe the machine shop can leave in the original bolts, cut them flush and redrill through that, thus staying away from the support ribs? I think I've confused myself with this...
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 12-28-2006, 04:20 PM   #4
gotchevys?
gotchevys?'s Avatar
Ive had rear axles redrilled for 6 lug to 5 on 5. Would it be possible to weld the old holes shut and then redrill? Probably a little more work but I would think it would be a better end result.
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 12-28-2006, 04:28 PM   #5
SCOTI
SCOTI's Avatar
I had to take material off of those 'ribs' when re-drilling the 5x5 truck pattern to the 5x4.75 car pattern on a stock 12" C10 truck rotor.
These re-drilled rotors have been used on a daily driven vehicle now for 6+yrs so I would say it won't be a problem.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
