Old 12-29-2006, 04:41 PM   #1
TraderJon
TraderJon's Avatar
under hood wire harness
Hello everyone
Hope everybody had a good Christmas,,,,,,,,I've
Been doing the bbc swap on the 67 & need to replace the engine harness from the firewall plug,just the tan & purple wire,I have the wire but need to know how to get the lil connectors out of the plug @ firewall to reuse them?
Headlight harness is good to go.
JFD
TraderJon is offline   Reply With Quote
Old 12-29-2006, 05:42 PM   #2
Bob Moore
Re: under hood wire harness
The male end which is what you see after pulling the engine plug loose from the firewall is a split tang blade. A small screw driver pushing on one side will cause the split to close up. Pull the wire straight out then. Use the same screw driver to spread out the tang when you are ready to reinstall.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-29-2006, 05:43 PM   #3
rage'nrat638
rage'nrat638's Avatar
there should be a little metal tab on the metal spade connector in the plug. you need to use a very small screw driver and stick it inside the front of the connector to bend it and pull the metal connector out of the plastic plug
a jewelers screw driver would work best as mentioned above
rage'nrat638 is offline   Reply With Quote
Old 12-30-2006, 01:38 PM   #4
TraderJon
TraderJon's Avatar
Thanks Ragenrat & Bob
It came out just like you said.
JFD
