Old 12-31-2006, 01:39 PM   #1
92470
Mystery dash light identification
This weekend I was replacing a couple burnt out dash lights in my 71' Cheyenne. When I pulled out one that was burnt out, I noticed that it wasn't like all the others that are just the black twist in's.
This one had a male prong factory attached to the back of it, but there wasn't a lead running into it. My dash has all guages by the way, but no tach. Everything seems to work, so what is the purpose of this prong, and is something supposed to be attached to it? It is located in the middle left of the dash. Any advice is appreciated. Thanks!
92470 is offline   Reply With Quote
Old 12-31-2006, 02:31 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Mystery dash light identification
That is for the fiber optic shifter light. When the bulb is lit up, it sends the light thru the fiber optic strands to the little orange indicator behind your shifter pointer lense. You are missing the fiber optic part. This is an old post showing the complete assembly:http://67-72chevytrucks.com/vboard/s...ht=fiber+optic
A couple of tips: When you find one, cut the very tips of the strands nice and uniform where it attaches to the pointer. Remove the old orange paint from the pointer and touch it up with a fresh thin coat of orange. It will look great during the day and at night!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-31-2006, 03:26 PM   #3
byrd
Union Electrician
byrd's Avatar
I have the set up for sale for $20 shipped if you need it, here is the for sale thread
http://67-72chevytrucks.com/vboard/s...d.php?t=216642
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-31-2006, 04:09 PM   #4
92470
Thanks for the information. This is very interesting. I'm going to have to look at my column again, I never noticed that before! It does have the bulb that works inside of the column that shines up on the gear indicator. I never knew there was anything more. I have a factory tilt column and it looks like the one you have is for a non-tilt. Any ideas where I can find a set up for a factory tilt?
Old 12-31-2006, 05:30 PM   #5
MT1972cheyenne
MT1972cheyenne's Avatar
The factory tilt doesn't use it.
MT1972cheyenne is offline   Reply With Quote
Old 01-01-2007, 02:36 AM   #6
Bob Moore
92470 - just when you get it figured out they change the rules on you. The tilt columns use a regular bulb and wire - not a fiber optic.
These old trucks are always fun and even after 15 years of fooling around with them I still learn new things.
I see were you have 14 posts so let me say welcome from SUNNY Washington - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
