Old 12-31-2006, 01:43 PM   #1
faribran
vortec heads on a 283
I am wanting to find out if anyone on here has put vortec heads on a 283.
any input welcome..
thanx
faribran is offline   Reply With Quote
Old 12-31-2006, 01:56 PM   #2
65-72 chevytoys
65-72 chevytoys's Avatar
Re: vortec heads on a 283
I have done it on a 350 but not a 283. Those heads will work on any 283-400 sbc. You will need a new vortec style intake. It should have the same effect as any other sbc. More volume of A/F mix into the cylinders = more power.
65-72 chevytoys is offline   Reply With Quote
Old 12-31-2006, 02:03 PM   #3
faribran
65-72,
thanks for the input...
i have most of the components ( intake etc) sure wanted to make the 283 screame if i could...i have a couple of 350 and 327 blocks lying around...
i thought i had read somewhere that the valves might make contact with the smaller diameter bore of the 283 block....
Old 12-31-2006, 02:50 PM   #4
qksilver
it shouldn't, I would use the 283 head gasket to double check.
qksilver is offline   Reply With Quote
Old 12-31-2006, 02:51 PM   #5
faribran
i should have thought of this.. but i didnt...
thanks. good idea
Old 12-31-2006, 03:53 PM   #6
crazy longhorn
Fabricate till you "puke"
The valves will clear the deck just fine.....he!!, you can run 2.02 /1.6 valves on a 3 7/8" bore, as long as you dont go past about .450 lift @ the valve. I sure dont reccomend that large a valve tho....doubt that you would gain anything, due to shrouding.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
