Commander Taco Bello
WTB Trailing Arms
I need a good set of trailing arms for my 69 LWB that i'm baggin'. Not to worried about bushings because i plan to put new in.
![]() Join Date: Nov 2002
Re: WTB Trailing Arms
i have a pair, but do you think they can be shipped ups??
pm sent
If it doesn't work for the last guy I have a set also.
the set he has in the pic are from a swb, but he is going to look for a lwb set tomorrow.
Not to mess up the sale but just to inform, I didn't think there was a difference between SWB and LWB trailing arms. I do know there is a difference between 1/2T and 3/4T arms but not SWB or LWB.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
bob, thanks for the info.
that brings up another question though. my truck was a 3/4 ton, but the PO converted it to 1/2 ton and did disk brakes up front and 5 lug wheels all the way around. I have no idea what he used for a doner truck, but how can i tell for sure that he converted to 1/2 ton trailing arms? |
![]() Join Date: Sep 2000
I sure you could get a pair down here when you get to come down.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
Active Member
From what I understand 3/4 & 1/2 ton trailing arms are the same with exception given to reinforcing the 3/4 ton units.
Can we get some 3/4 ton owners to post some pictures?
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
I believe ECE sells(as probably do other board vendors) reinforcement kits. Look at their catalog to see what they look like. Basically they are a piece of 1/8th(approx) plate spot welded along the top and bottom of the arms. They are about 15" long and are at the back of the arms. It looks like they add strength by tying the 2 halves together.
Hope this helps - Bob
Junior Member
im looking for a good set of trailing arms pm me if anyone has a good set. mine are rusted and some of the rivots are missing
![]() Join Date: Aug 2006
I have a c-20 and has the support flatstock tacked on the top and bottom at the spring area. If anyone has a good set I need them also and I will take either 1/2 or 3/4t. Thanks.
if any one needs a set i have a clean set off a 1/2 ton sub?
