01-01-2007, 07:04 PM | #1 |
1/2 ton ton 3/4 conversion
My brother is wanting to convert his 78 1/2 ton swb 4x4 to a 3/4. He already has a front axle and want to use a 14b for the rear axle. My question is what will it take to convert the rear from a 12b to 14b. Does this require a "trick u joint".
thanks Mark
THERE is NO REPLACEMENT FOR DISPLACEMENT 1971 CHEVY 4X4 4SPD 406 CHEVY Lockers front and back 1978 BONNEVILLE 403 OLDS 1985 K1500 F5L912 Deutz Power (work in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=389561 1963 Oliver 1600 diesel 1956 Oliver Super 88 |
01-01-2007, 07:32 PM | #2 |
Re: 1/2 ton ton 3/4 conversion
If you get a rear out of a 70s 3/4 ton, that part will bolt in. Might need to get a conversion joint, but I've seen 12b's with a 1350 on them. Shock mounts may have to be moved too.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-01-2007, 08:34 PM | #3 |
yes to convert 1/2 to 3/4 the rear drive shaft joint is a special one go to your local napa dealer the will have them i will try to find the part number.
01-04-2007, 12:42 AM | #4 |
When I did my suburban I went to Advance Auto Parts to get my U-Joint
Part # 21153 for $22.88
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
01-08-2007, 06:57 PM | #5 |
When I converted from 1/2 ton to 3/4 ton on my 1970, I had my driveshaft shortened and installed the correct 3/4 ton yoke. By using the correct u-joint, it's much easier to get a replacement when needed and cheaper. The nose of the 3/4 ton differential is longer than the 1/2 ton.
