Old 01-01-2007, 10:08 PM   #1
pcmcobra
pcmcobra's Avatar
front springs on 86 c10 question
Hey guys,
I'm about to drop my truck. Bought 3" spindles and 1" springs...
As for getting the stock springs out, who uses a spring compressor, or is it really needed?
Ever had any problems NOT using one to get the stock springs out?
thx
pcmcobra is offline   Reply With Quote
Old 01-01-2007, 10:13 PM   #2
poorboy
poorboy's Avatar
Re: front springs on 86 c10 question
You can bust everything loose and have the jack under the lower control arm. Lower it slowly and it should be fine. I've done it several times and never had an issue with it.
poorboy is offline   Reply With Quote
Old 01-01-2007, 10:28 PM   #3
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
^^what he siad, put the jack under the lca, pop the bottom ball joint off the spindle, thn lower the lca. make sure the truck is high enough so you can lower the lca all the way
'85 swb
droppedgmc is offline   Reply With Quote
Old 01-01-2007, 10:59 PM   #4
pcmcobra
pcmcobra's Avatar
thx all
Old 01-02-2007, 12:47 AM   #5
SCOTI
SCOTI's Avatar
If the spring is stock height, it might still be under a lot of pressure & want to 'pop' out. This can be potentially dangerous.
A simple trick to keep this from happening is to wrap something (rope, strap, wire, chain) around 1 of the coils before releasing the tension on the spring. If it wants to pop out, you have a tether on it keeping it under control.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
